Framework Laptop 13 Pro Input Cover Replacement
    1. Framework Laptop 13 Pro Input Cover Replacement, Before you begin: step 1, image 1 of 2 Framework Laptop 13 Pro Input Cover Replacement, Before you begin: step 1, image 2 of 2
      • Unplug all cables and fully shut down your laptop from the OS.
      Ask FixBot
    1. Framework Laptop 13 Pro Input Cover Replacement, Loosen the Input Cover screws: step 2, image 1 of 2 Framework Laptop 13 Pro Input Cover Replacement, Loosen the Input Cover screws: step 2, image 2 of 2
      • Use your Framework Screwdriver to loosen the five captive T5 Torx screws securing the Input Cover.
      Ask FixBot
    2. Framework Laptop 13 Pro Input Cover Replacement, Lift the Input Cover: step 3, image 1 of 2 Framework Laptop 13 Pro Input Cover Replacement, Lift the Input Cover: step 3, image 2 of 2
      • Flip over your laptop and open it.
      • Use your fingers to lift the Input Cover up and release it from its magnets.
      • Don't fully remove the Input Cover yet, as it's still attached by the Touchpad Cable.
      • If you're having trouble lifting the Input Cover, you can leverage the gap at the bottom right corner to get your fingers fully under it.
      Ask FixBot
    3. Framework Laptop 13 Pro Input Cover Replacement, Flip over the Input Cover: step 4, image 1 of 2 Framework Laptop 13 Pro Input Cover Replacement, Flip over the Input Cover: step 4, image 2 of 2
      • Flip the top of the Input Cover so the Keyboard is facing down.
      • Rest the Input Cover over the Battery, making sure the Touchpad Cable isn't being strained.
      • If the LEDs on the left and right sides of the Mainboard are flashing, then your laptop is still powered on. Make sure your laptop is completely powered off before continuing.
      Ask FixBot
    4. Framework Laptop 13 Pro Input Cover Replacement, Disconnect the Touchpad Cable: step 5, image 1 of 2 Framework Laptop 13 Pro Input Cover Replacement, Disconnect the Touchpad Cable: step 5, image 2 of 2
      • Insert your finger into the Touchpad Cable press connector loop.
      • Lift up to disconnect the Touchpad Cable from the Mainboard.
      Ask FixBot
    5. Framework Laptop 13 Pro Input Cover Replacement, Remove the Input Cover: step 6, image 1 of 2 Framework Laptop 13 Pro Input Cover Replacement, Remove the Input Cover: step 6, image 2 of 2
      • Remove the Input Cover.
      Ask FixBot
    1. Framework Laptop 13 Pro Input Cover Replacement, Disassembly complete: step 7, image 1 of 1
      • Congratulations on completing disassembly! The remaining steps will show how to reassemble your Framework Laptop.
      Ask FixBot
    1. Framework Laptop 13 Pro Input Cover Replacement, Position the Input Cover: step 8, image 1 of 2 Framework Laptop 13 Pro Input Cover Replacement, Position the Input Cover: step 8, image 2 of 2
      • Position the Input Cover, Keyboard down, on top of the laptop so it just covers the Battery.
      • This allows the Touchpad Cable to be folded over and reconnected without straining it.
      Ask FixBot
    2. Framework Laptop 13 Pro Input Cover Replacement, Connect the Touchpad Cable: step 9, image 1 of 2 Framework Laptop 13 Pro Input Cover Replacement, Connect the Touchpad Cable: step 9, image 2 of 2
      • Align the press connector over its socket and press down with your finger.
      • You should hear it "click" into place. If you're having trouble, reposition it and try again. Don't try to force the connector into place.
      Ask FixBot
    3. Framework Laptop 13 Pro Input Cover Replacement, Place the Input Cover: step 10, image 1 of 2 Framework Laptop 13 Pro Input Cover Replacement, Place the Input Cover: step 10, image 2 of 2
      • Flip the Input Cover over the laptop and align the bottom edges.
      Ask FixBot
    4. Framework Laptop 13 Pro Input Cover Replacement: step 11, image 1 of 3 Framework Laptop 13 Pro Input Cover Replacement: step 11, image 2 of 3 Framework Laptop 13 Pro Input Cover Replacement: step 11, image 3 of 3
      • Lay the Input Cover over the laptop and let the magnets snap it into place.
      • The bottom right corner of the Input Cover won't sit flush with the laptop until you tighten its screws.
      Ask FixBot
    5. Framework Laptop 13 Pro Input Cover Replacement, Reposition the laptop: step 12, image 1 of 1
      • Close the laptop and flip it over.
      Ask FixBot
    6. Framework Laptop 13 Pro Input Cover Replacement, Tighten the Input Cover screws: step 13, image 1 of 2 Framework Laptop 13 Pro Input Cover Replacement, Tighten the Input Cover screws: step 13, image 2 of 2
      • Use your Framework Screwdriver to tighten the five captive T5 Torx screws securing the Input Cover.
      • Don't overtighten the screws—just make sure they're snug.
      Ask FixBot
You finished fixing your Framework Laptop!
If you need help, contact Framework support.
Alex Diaz-Kokaisl
250,345 Reputation
1,203 Guides authored
0 Guide Comments
Past 24 Hours: 2
Past 7 Days: 23
Past 30 Days: 104
All Time: 229
