Framework Laptop 12 eDP Display Cable Installation
Prerequisite Only
This is a prerequisite-only guide! This guide is part of another procedure and isn’t meant to be used alone.
    1. Framework Laptop 12 eDP Display Cable Installation, Install the eDP display cable: step 1, image 1 of 2 Framework Laptop 12 eDP Display Cable Installation, Install the eDP display cable: step 1, image 2 of 2
      • Use your fingers to grab the display cable by the clear tab and the locking bar.
      • Align the display cable with its connector and slide it in until it's fully seated.
      Ask FixBot
    2. Framework Laptop 12 eDP Display Cable Installation: step 2, image 1 of 2 Framework Laptop 12 eDP Display Cable Installation: step 2, image 2 of 2
      • Swing the locking bar down over the connector.
      • If the locking bar can't swing all the way down around the connector, you'll need to insert the cable deeper into the connector.
      • Lay the clear tab over the connector and press it onto the display.
      Ask FixBot
    3. Framework Laptop 12 eDP Display Cable Installation: step 3, image 1 of 3 Framework Laptop 12 eDP Display Cable Installation: step 3, image 2 of 3 Framework Laptop 12 eDP Display Cable Installation: step 3, image 3 of 3
      • Slide the touch control cable into the ZIF connector up to the printed line on the cable.
      • Use your finger to flip down and gently press the locking tab in place.
      Ask FixBot
    4. Framework Laptop 12 eDP Display Cable Installation: step 4, image 1 of 2 Framework Laptop 12 eDP Display Cable Installation: step 4, image 2 of 2
      • Use your finger to press the display cable grounding tape onto the display.
      • Use your fingers to press the display cable onto the metal back of the display.
      Ask FixBot
Finish Line
Arthur Shi
350,781 Reputation
938 Guides authored
0 Guide Comments
Past 24 Hours: 0
Past 7 Days: 3
Past 30 Days: 15
All Time: 121
