Framework Laptop 12 Wi-Fi Card Installation
Prerequisite Only
This is a prerequisite-only guide! This guide is part of another procedure and isn’t meant to be used alone.
    1. Framework Laptop 12 Wi-Fi Card Installation, Install the Wi-Fi card: step 1, image 1 of 2 Framework Laptop 12 Wi-Fi Card Installation, Install the Wi-Fi card: step 1, image 2 of 2
      • Hold the Wi-Fi card by its edges. Don't touch the gold contacts with your fingers. If you do, wipe the contacts with a clean, lint-free cloth to remove any finger oils.
      • Align the Wi-Fi card's gold contacts and notch with the socket on the Mainboard.
      • Insert the Wi-Fi card into the socket at a shallow angle. The gold contacts should mostly be covered by the socket.
      • The Wi-Fi card fits into the socket in one orientation. If it doesn't fit, try flipping the module.
      Ask FixBot
    2. Framework Laptop 12 Wi-Fi Card Installation: step 2, image 1 of 3 Framework Laptop 12 Wi-Fi Card Installation: step 2, image 2 of 3 Framework Laptop 12 Wi-Fi Card Installation: step 2, image 3 of 3
      • Hold the Wi-Fi card down with your finger.
      • Position the black antenna cable connector over the left Wi-Fi card's coaxial socket.
      • Tweezers can help position the connector.
      • Use your finger to press the connector into place. You should feel a faint click, and the cable will stay attached to the socket by itself.
      • These connectors are very delicate! If the connector doesn't feel like it's clicking in place, reposition the connector and try again.
      • Repeat the procedure with the white antenna cable.
      Ask FixBot
    3. Framework Laptop 12 Wi-Fi Card Installation: step 3, image 1 of 2 Framework Laptop 12 Wi-Fi Card Installation: step 3, image 2 of 2
      • Slide the Wi-Fi bracket over the top edge of the Wi-Fi card.
      Ask FixBot
    4. Framework Laptop 12 Wi-Fi Card Installation: step 4, image 1 of 1
      • Use your Framework Screwdriver to tighten the captive T5 Torx screw to secure the Wi-Fi card.
      Ask FixBot
Finish Line
Arthur Shi
350,908 Reputation
938 Guides authored
0 Guide Comments
Past 24 Hours: 0
Past 7 Days: 3
Past 30 Days: 9
All Time: 122
