Up to 20% off select tools
Framework Laptop 12 Touchpad Installation
View statistics:
Past 24 Hours:
0
Past 7 Days:
Past 30 Days:
9
All Time:
150
Comments: 0
Go to guide comments
Completed: 0
Favorites: 0
Time Required: 15 - 45 minutes
Difficulty: Moderate
Prerequisite Only
This is a prerequisite-only guide! This guide is part of another procedure and isn’t meant to be used alone.
Introduction
Go to step 1 ↓
Touchpad installation prereq guide
    1. Framework Laptop 12 Touchpad Installation, Align the replacement touchpad: step 1, image 1 of 1
      • The replacement touchpad comes with a blue plastic alignment tool pre-installed. Don't remove this from the touchpad yet.
      • Make sure the small tabs around the alignment tool are folded down around the touchpad. Use your fingers to fold them down if they're not.
      Ask FixBot
    2. Framework Laptop 12 Touchpad Installation: step 2, image 1 of 2 Framework Laptop 12 Touchpad Installation: step 2, image 2 of 2
      • Lay the touchpad into its Input Cover recess.
      • The tabs on the alignment tool will center the touchpad on the Input Cover.
      Ask FixBot
    3. Framework Laptop 12 Touchpad Installation, Install the touchpad screws: step 3, image 1 of 2 Framework Laptop 12 Touchpad Installation, Install the touchpad screws: step 3, image 2 of 2
      • Use your Framework Screwdriver to install the seven 2.1 mm‑long T5 Torx screws to secure the touchpad.
      • If you didn't use an alignment tool, manually center the touchpad to the Input Cover before tightening the screws.
      • Tighten the screws until they're snug. Don't over-tighten them, or you may strip the screws.
      Ask FixBot
    4. Framework Laptop 12 Touchpad Installation, Connect the touchpad cables: step 4, image 1 of 3 Framework Laptop 12 Touchpad Installation, Connect the touchpad cables: step 4, image 2 of 3 Framework Laptop 12 Touchpad Installation, Connect the touchpad cables: step 4, image 3 of 3
      • Slide the keyboard ZIF cable into its connector, up to the printed line on the cable.
      • Use your finger to flip down and gently press the locking tab in place.
      Ask FixBot
    5. Framework Laptop 12 Touchpad Installation: step 5, image 1 of 3 Framework Laptop 12 Touchpad Installation: step 5, image 2 of 3 Framework Laptop 12 Touchpad Installation: step 5, image 3 of 3
      • Slide the touchpad ZIF cable into its connector, up to the printed line on the cable.
      Ask FixBot
    6. Framework Laptop 12 Touchpad Installation, Remove the alignment tool: step 6, image 1 of 2 Framework Laptop 12 Touchpad Installation, Remove the alignment tool: step 6, image 2 of 2
      • Skip this step if you didn't use an alignment tool.
      • Use your fingers to peel and remove the alignment tool from the touchpad.
      Ask FixBot
Finish Line
Arthur Shi
354,299 Reputation
938 Guides authored
0 Guide Comments
Past 24 Hours: 0
Past 7 Days: 1
Past 30 Days: 9
All Time: 150
