Framework Laptop 12 Stylus Tip Replacement
    1. Framework Laptop 12 Stylus Tip Replacement, Pull the tip out of the Stylus: step 1, image 1 of 3 Framework Laptop 12 Stylus Tip Replacement, Pull the tip out of the Stylus: step 1, image 2 of 3 Framework Laptop 12 Stylus Tip Replacement, Pull the tip out of the Stylus: step 1, image 3 of 3
      Ask FixBot
    2. Framework Laptop 12 Stylus Tip Replacement, Insert the tip: step 2, image 1 of 3 Framework Laptop 12 Stylus Tip Replacement, Insert the tip: step 2, image 2 of 3 Framework Laptop 12 Stylus Tip Replacement, Insert the tip: step 2, image 3 of 3
      • Use your fingers to slide the new tip into the Stylus.
      • Push the tip in until it bottoms out. It should be able to spin but not fall out.
      Ask FixBot
If you need help, contact Framework support.
Arthur Shi
350,754 Reputation
938 Guides authored
0 Guide Comments
Past 24 Hours: 3
Past 7 Days: 25
Past 30 Days: 79
All Time: 493
