Up to 20% off select tools
Framework Laptop 12 Memory Module Installation [Updated]
View statistics:
Past 24 Hours:
Past 7 Days:
4
Past 30 Days:
10
All Time:
51
Comments: 0
Go to guide comments
Completed: 0
Favorites: 0
Time Required: 5 - 15 minutes
Difficulty: Easy
Prerequisite Only
This is a prerequisite-only guide! This guide is part of another procedure and isn’t meant to be used alone.
Introduction
Go to step 1 ↓
Updated memory module/RAM installation prereq guide
    1. Framework Laptop 12 Memory Module Installation [Updated], Install the memory module: step 1, image 1 of 3 Framework Laptop 12 Memory Module Installation [Updated], Install the memory module: step 1, image 2 of 3 Framework Laptop 12 Memory Module Installation [Updated], Install the memory module: step 1, image 3 of 3
      • Hold the memory module by its edges. Don't touch the gold contacts with your fingers. If you do, wipe the contacts with a clean, lint-free cloth to remove any finger oils.
      • Align the notch on the memory module with the ridge in the socket.
      • Insert the contact edge into the socket at a shallow angle. The gold contacts should mostly be covered by the socket.
      • Intel Core Series 3 Mainboards have the RAM flipped compared to these images. The shorter side of connectors will be on the left.
      • Press the edges of the memory module down until the side clips lock it in place.
      Ask FixBot
    2. Framework Laptop 12 Memory Module Installation [Updated]: step 2, image 1 of 2 Framework Laptop 12 Memory Module Installation [Updated]: step 2, image 2 of 2
      • Flip the memory flap back over the memory module.
      Ask FixBot
Finish Line
Arthur Shi
354,275 Reputation
938 Guides authored
0 Guide Comments
Past 24 Hours: 1
Past 7 Days: 4
Past 30 Days: 10
All Time: 51
