Shop the Holiday Gift Guide
Framework Laptop 12 Hinge (Right) Installation
View statistics:
Past 24 Hours:
0
Past 7 Days:
0
Past 30 Days:
0
All Time:
101
Comments: 0
Go to guide comments
Completed: 0
Favorites: 0
Time Required: 45 minutes - 2 hours
Difficulty: Moderate
Prerequisite Only
This is a prerequisite-only guide! This guide is part of another procedure and isn’t meant to be used alone.
Introduction
Go to step 1 ↓
Right hinge installation prereq guide
    1. Framework Laptop 12 Hinge (Right) Installation, Install the right hinge: step 1, image 1 of 3 Framework Laptop 12 Hinge (Right) Installation, Install the right hinge: step 1, image 2 of 3 Framework Laptop 12 Hinge (Right) Installation, Install the right hinge: step 1, image 3 of 3
      • Place the cable clip around the cables, where they were bent from being inserted into the hinge.
      • Use your fingers to press the clip into the hinge to secure the cables.
      • Make sure the cables are properly routed in the Top Cover.
      Ask FixBot
    2. Framework Laptop 12 Hinge (Right) Installation: step 2, image 1 of 2 Framework Laptop 12 Hinge (Right) Installation: step 2, image 2 of 2
      • Use your fingers to place the right hinge back in place in the Top Cover.
      Ask FixBot
    3. Framework Laptop 12 Hinge (Right) Installation: step 3, image 1 of 2 Framework Laptop 12 Hinge (Right) Installation: step 3, image 2 of 2
      • Use your fingers to carefully swing the display over so it lies face-down on your work surface.
      Ask FixBot
    4. Framework Laptop 12 Hinge (Right) Installation: step 4, image 1 of 1
      • Use your Framework Screwdriver to install the two 2.4 mm‑long T5 Torx screws to secure the right hinge to the Top Cover.
      • Make sure to install these screws in the marked locations. There's one additional screw hole on the hinge that's not for these screws.
      Ask FixBot
Finish Line
Arthur Shi
353,975 Reputation
938 Guides authored
0 Guide Comments
Past 24 Hours: 0
Past 7 Days: 0
Past 30 Days: 0
All Time: 101
