Shop the Holiday Gift Guide
Framework Laptop 12 Hinge (Both) Installation
View statistics:
Past 24 Hours:
2
Past 7 Days:
5
Past 30 Days:
9
All Time:
146
Comments: 0
Go to guide comments
Completed: 0
Favorites: 0
Time Required: 45 minutes - 2 hours
Difficulty: Moderate
Prerequisite Only
This is a prerequisite-only guide! This guide is part of another procedure and isn’t meant to be used alone.
Introduction
Go to step 1 ↓
Both hinges installation prereq guide
    1. Framework Laptop 12 Hinge (Both) Installation, Install the hinges: step 1, image 1 of 3 Framework Laptop 12 Hinge (Both) Installation, Install the hinges: step 1, image 2 of 3 Framework Laptop 12 Hinge (Both) Installation, Install the hinges: step 1, image 3 of 3
      • Lay both hinges in place in the Top Cover.
      • Use the alignment pins to help position each hinge in place.
      Ask FixBot
    2. Framework Laptop 12 Hinge (Both) Installation: step 2, image 1 of 2 Framework Laptop 12 Hinge (Both) Installation: step 2, image 2 of 2
      • Make sure both antenna cables are properly routed in the Top Cover and tucked into the hinges, as shown in the images.
      Ask FixBot
    3. Framework Laptop 12 Hinge (Both) Installation: step 3, image 1 of 2 Framework Laptop 12 Hinge (Both) Installation: step 3, image 2 of 2
      • Use your Framework Screwdriver to install the four 2.5 mm‑long T5 Torx screws to secure the two hinges to the Top Cover.
      • Make sure to install these screws in the marked locations. There are additional screw holes on the hinges that are not for these screws.
      • Make sure you don't accidentally install the silver lower hinge screws here. These screws should be gold colored.
      Ask FixBot
Finish Line
Arthur Shi
353,975 Reputation
938 Guides authored
0 Guide Comments
Past 24 Hours: 2
Past 7 Days: 5
Past 30 Days: 9
All Time: 146
