Shop the Holiday Gift Guide
Framework Laptop 12 Display Cover Removal
View statistics:
Past 24 Hours:
4
Past 7 Days:
5
Past 30 Days:
9
All Time:
145
Comments: 0
Go to guide comments
Completed: 0
Favorites: 0
Time Required: 1 - 5 minutes
Difficulty: Easy
Prerequisite Only
This is a prerequisite-only guide! This guide is part of another procedure and isn’t meant to be used alone.
Introduction
Go to step 1 ↓
Display Cover removal prereq guide
    1. Framework Laptop 12 Display Cover Removal, Power down your laptop: step 1, image 1 of 3 Framework Laptop 12 Display Cover Removal, Power down your laptop: step 1, image 2 of 3 Framework Laptop 12 Display Cover Removal, Power down your laptop: step 1, image 3 of 3
      • Before you begin repairs, unplug your laptop and shut it down from the operating system. This ensures that the laptop isn't in standby/suspend mode.
      • The indicator LEDs along the edges should be unlit. The laptop should be silent.
      • If you accidentally turn on the laptop during repair, hold the power button down for 10 seconds to shut it down.
      • Make sure your Framework Screwdriver has the T5 Torx bit (labeled as T-5) facing outwards. If it's not, pull the bit out and flip it.
      Ask FixBot
    1. Framework Laptop 12 Display Cover Removal, Open your laptop: step 2, image 1 of 2 Framework Laptop 12 Display Cover Removal, Open your laptop: step 2, image 2 of 2
      • Open the laptop lid so that both the screen and the base lie flat on your work surface.
      Ask FixBot
    2. Framework Laptop 12 Display Cover Removal, Remove the Display Cover: step 3, image 1 of 2 Framework Laptop 12 Display Cover Removal, Remove the Display Cover: step 3, image 2 of 2
      • The Display Cover is held in place with magnets along the top edge and clips along the remaining edges.
      • Use the flat end of your Framework Screwdriver to pry up the right edge of the Display Cover.
      Ask FixBot
    3. Framework Laptop 12 Display Cover Removal: step 4, image 1 of 3 Framework Laptop 12 Display Cover Removal: step 4, image 2 of 3 Framework Laptop 12 Display Cover Removal: step 4, image 3 of 3
      • Slide your fingers under the top edge of the Display Cover to release it from the laptop.
      Ask FixBot
    4. Framework Laptop 12 Display Cover Removal: step 5, image 1 of 2 Framework Laptop 12 Display Cover Removal: step 5, image 2 of 2
      • Remove the Display Cover.
      Ask FixBot
Finish Line
Arthur Shi
353,987 Reputation
938 Guides authored
0 Guide Comments
Past 24 Hours: 4
Past 7 Days: 5
Past 30 Days: 9
All Time: 145
