Introduction
How to reconnect the Mainboard with the RAM, SSD, and heatsink attached. Also reconnect the Top Cover from the Bottom Cover.
This is the installation version of the Bottom Cover Disconnect prereq.
Use your fingers to lift the Top Cover hinges over the Bottom Cover lip.
Lay the hinges in place in the Bottom Cover.
Carefully lay the Mainboard in the laptop.
Use the two alignment pins to help align the Mainboard to the laptop.
Be careful not to trap the webcam, display, and antenna cables under the Mainboard as you set it in place.
