Framework Laptop 12 Antennas Installation
Prerequisite Only
This is a prerequisite-only guide! This guide is part of another procedure and isn’t meant to be used alone.
    1. Framework Laptop 12 Antennas Installation, Install the antennas: step 1, image 1 of 3 Framework Laptop 12 Antennas Installation, Install the antennas: step 1, image 2 of 3 Framework Laptop 12 Antennas Installation, Install the antennas: step 1, image 3 of 3
      • To install the antennas, you'll fasten them onto the frame first, then route each antenna cable into its Top Cover channel.
      • Lay each antenna in place in the Top Cover.
      Ask FixBot
    2. Framework Laptop 12 Antennas Installation: step 2, image 1 of 2 Framework Laptop 12 Antennas Installation: step 2, image 2 of 2
      • Use your Framework Screwdriver to install the two (one per antenna) 2.5 mm‑long T5 Torx screws to secure the antennas to the Top Cover.
      Ask FixBot
    3. Framework Laptop 12 Antennas Installation: step 3, image 1 of 2 Framework Laptop 12 Antennas Installation: step 3, image 2 of 2
      • Use your fingers and your Framework Screwdriver to carefully guide each antenna cable back into its channel.
      • Zoom in on the second photo to see how the antenna cables sit in their channels.
      Ask FixBot
Finish Line
Arthur Shi
350,880 Reputation
938 Guides authored
0 Guide Comments
Past 24 Hours: 1
Past 7 Days: 5
Past 30 Days: 15
All Time: 130
