OEM Guide
iFixit collaborated with the manufacturer to make this guide.
Introduction
Go to step 1 ↓Congratulations on getting the Framework Desktop DIY Edition! Follow this quick start guide to assemble your Desktop and get it running.
Framework Desktop chassis with pre-installed Mainboard, Heatsink, Power Supply, Top Panel, and Front Panel
Left Panel—either the Black or Translucent version
Framework Desktop Screwdriver
At least 21 Tiles for the Front Panel
Use your finger to lift up the two D-rings on the Top Panel screws.
Slide the Top Panel towards the rear of the computer to release the clips securing it to the chassis.
Lift the Top Panel off the chassis and remove it.
Lay the Desktop on its right side so its exposed internals are facing upward.
Make sure your Framework Desktop Screwdriver has the T5 Torx bit (labeled as T5) facing outwards. If it's not, pull the bit out and flip it.
Use your Framework Desktop Screwdriver to loosen the captive screw T5 Torx securing the primary storage heat spreader.
While securing the primary storage heat spreader with one hand, use your Framework Desktop Screwdriver to remove the 4.5 mm‑long T5 Torx screw securing it.
Lift the primary storage heat spreader out of the Desktop and remove it.
Follow the guide normally, making sure to ignore instructions that involve the primary storage heat spreader.
While holding the heat spreader upright, align the SSD's gold contacts with its socket.
Insert the SSD into the socket at a shallow angle. The gold contacts should mostly be covered by the socket.
Lay the heat spreader back onto the SSD.
Orient the fan so its label is facing downward and the cable(s) is pointing towards the top of the computer.
Lay the fan on top of the heatsink, making sure the cable(s) are routed so they poke out of the hole on the top of the computer.
Lay the fan duct on top of the fan with the lip facing upward.
Align the screw holes on the fan duct with the ones on the fan.
Remove the fan screws from their packaging and make sure there are four screws total.
Orient the main fan cable so its two vertical lines are facing you.
Slide the main fan cable over the four-pronged connector labeled "APU Fan," making sure the orange label slots between the vertical lines.
Orient the RGB cable so the arrow is on the right side of the connector.
Use your fingers to slide the RGB cable over the three pronged connector located to the right of the "APU Fan" connector.
Slide the Left Panel onto the left edge of the chassis, from top to bottom, and press it flat to ensure its clips are slotted into place.
Push the Left Panel towards the base of the computer to engage the clips.
Use your fingers to grip the top of the Right Panel and slide it upward to release its clips.
Remove the Right Panel.
Lay the left side of the Desktop on your work surface so the Mainboard is facing upward.
Use your Framework Desktop Screwdriver to loosen the captive T5 Torx screw securing the secondary storage.
While securing the secondary storage heat spreader with one hand, use your Framework Desktop Screwdriver to remove the 4.5 mm‑long T5 Torx screw securing it.
Lift the secondary storage heat spreader out of the Desktop and remove it.
Follow the guide normally, making sure to ignore instructions that involve the secondary heat spreader.
Insert the SSD into the socket at a shallow angle. The gold contacts should be mostly covered by the socket.
Slide the Right Panel onto the right edge of the chassis and press it flat to ensure its clips are slotted into place.
Push the Right Panel towards the base of the computer to engage the clips.
Orient the Top Panel so its arrow is pointing towards the rear of the computer.
While holding the Top Panel at a slight downward angle, slide it across the top of the chassis (from rear to front) until you feel its clips catch.
Lay the Top Panel flat on the chassis to align the remaining clips.
Insert the Top Panel screw into its hole and twist clockwise until it feels snug.
Use your fingers to pull the Front Panel off the magnets securing it to the chassis.
Lay a Tile over an open slot on the Front Panel.
Use your fingers to press the tile into the slot and engage the clips.
Lay the bottom of the Front Panel on the small, protruding lip in the silver base to align its tabs.
Press the Front Panel flat to the chassis and let it align to the magnets.
Slide an Expansion Card into an Expansion Card slot.
Repeat for the other Expansion Card slot.
Plug the AC Cable into the back of the Desktop.
Plug the AC Cable into a power outlet.Â
If your Left Panel came with a protective liner, remove it.
Press the power button on the bottom right of the Front Panel to turn the Desktop on.
You're done assembling your Framework Desktop! Now, you'll need to install an OS.
For drivers, firmware, and software updates, check out this page.
If you need help, contact Framework support.
