Flydigi Vader 4 Pro Battery Replacement
    1. Flydigi Vader 4 Pro Battery Replacement, Front Case: step 1, image 1 of 3 Flydigi Vader 4 Pro Battery Replacement, Front Case: step 1, image 2 of 3 Flydigi Vader 4 Pro Battery Replacement, Front Case: step 1, image 3 of 3
      • Remove the four 10 mm screws on the rear case using a Phillips #0 screwdriver.
      Ask FixBot
    2. Flydigi Vader 4 Pro Battery Replacement: step 2, image 1 of 2 Flydigi Vader 4 Pro Battery Replacement: step 2, image 2 of 2
      • Insert an opening pick into the seam between the rear and front case.
      • Pry around the perimeter of the controller.
      • Remove the rear case and set it to the side of the front case, with care not to strain the connected cable.
      Ask FixBot
    3. Flydigi Vader 4 Pro Battery Replacement: step 3, image 1 of 1
      • Disconnect the JST-PH connector from its motherboard socket.
      Ask FixBot
    1. Flydigi Vader 4 Pro Battery Replacement, Battery: step 4, image 1 of 1
      • Pull the white battery connector directly up and out of its motherboard socket.
      • Slide an opening pick under the battery to sever the adhesive securing it to the mainboard.
      • Take care not to bend, warp, twist, or puncture the battery.
      • Lift the battery up and out.
      Ask FixBot
For optimal performance, after completing this guide, calibrate your newly installed battery.
Repair didn’t go as planned? Try some basic troubleshooting or ask our Answers community for help.
Connor Bassolino
25,929 Reputation
125 Guides authored
0 Guide Comments
Past 24 Hours: 7
Past 7 Days: 62
Past 30 Days: 209
All Time: 563
