Flydigi Direwolf 2 Battery Replacement
    1. Flydigi Direwolf 2 Battery Replacement, Rear Case: step 1, image 1 of 1
      • Remove the four 10 mm-long Phillips 10mm screws securing the rear case to the front case.
      Ask FixBot
    2. Flydigi Direwolf 2 Battery Replacement: step 2, image 1 of 3 Flydigi Direwolf 2 Battery Replacement: step 2, image 2 of 3 Flydigi Direwolf 2 Battery Replacement: step 2, image 3 of 3
      • Insert an opening pick into the seam between the rear and front case.
      • Slide the pick around the perimeter of the controller until the two halves of the controller release.
      • Remove the rear case.
      Ask FixBot
    1. Flydigi Direwolf 2 Battery Replacement, Battery: step 3, image 1 of 1
      • Lift the battery connector directly out of its socket.
      • Slide an opening pick underneath the battery to sever the adhesive securing it.
      • Take care not to bend, twist, or puncture the battery during removal.
      • Gently lift the battery out.
      Ask FixBot
For optimal performance, after completing this guide, calibrate your newly installed battery.
Repair didn’t go as planned? Try some basic troubleshooting or ask our Answers community for help.
3 other people completed this guide.
0 Guide Comments
Past 24 Hours: 5
Past 7 Days: 25
Past 30 Days: 87
All Time: 292
