Flipper Zero NFC antenna Replacement
      • Go to Main Menu > Settings > Power.
      • Select Power OFF.
      • Alternatively, you can press and hold the Back-button for around 10 seconds.
      • Confirm by pressing the Right-button.
      Ask FixBot
    1. Flipper Zero NFC antenna Replacement, Remove the microSD card: step 2, image 1 of 1
      • Eject the microSD card by pressing it with your fingernail.
      Ask FixBot
    2. Flipper Zero NFC antenna Replacement, Remove the screws: step 3, image 1 of 1
      Tool used on this step:
      Phillips #0 Screwdriver
      $5.49
      Buy
      • Use a PH0 screwdriver to unscrew the four long screws holding the back cover.
      • Be careful, the screws are quite easy to strip.
      Ask FixBot
    3. Flipper Zero NFC antenna Replacement, Open the back cover: step 4, image 1 of 3 Flipper Zero NFC antenna Replacement, Open the back cover: step 4, image 2 of 3 Flipper Zero NFC antenna Replacement, Open the back cover: step 4, image 3 of 3
      • Press the middle of the top cover on both sides, one by one, to release the latches that hold the back cover in place.
      • Once the latches are released, you can remove the bottom cover.
      Ask FixBot
    1. Flipper Zero NFC antenna Replacement, Remove the antenna: step 5, image 1 of 3 Flipper Zero NFC antenna Replacement, Remove the antenna: step 5, image 2 of 3 Flipper Zero NFC antenna Replacement, Remove the antenna: step 5, image 3 of 3
      iFixit Opening Picks (Set of 6)
      $4.95
      Buy
      • The board with the NFC antenna is glued to the bottom cover with adhesive tape.
      • To remove the board, gently pry one of the edges of the board with a plastic pick to peel off the adhesive tape.
      • Gently pull out the rest of the board by hand.
      Ask FixBot
To reassemble your device, follow these instructions in reverse order and apply new adhesive where needed.
Sebastian
33,672 Reputation
72 Guides authored
3 Guide Comments
Bonjour, où trouve-t'on cette antenne de rechange svp ?
christelle Poulailleau - Reply Share
Il n'y a actuellement aucune antenne de remplacement officielle en vente, mais vous pourriez acheter un Flipper Zero défectueux sur eBay et l'utiliser comme donneur, ou tenter votre chance sur AliExpress.
Sebastian - Reply Share
Where can I buy a replacement rfc card itself?
My son broke it changing the cover
C Mac - Reply Share
Past 24 Hours: 3
Past 7 Days: 23
Past 30 Days: 99
All Time: 4,073
