Shop the Holiday Gift Guide
Fix unstable bluetooth connection
View statistics:
Past 24 Hours:
8
Past 7 Days:
40
Past 30 Days:
135
All Time:
775
Comments: 0
Go to guide comments
Completed: 0
Favorites: 0
Time Required: No estimate
Difficulty: Moderate
Community-Contributed Guide
Introduction
Go to step 1 ↓
Because of manufacturing tolerances the antenna inside the earbuds is sometimes not connected. This guide shows how to fix this to get a more reliable connection.
To check which side(s) have the problem follow these easy steps:
  1. Take one of the earbuds from the case.
  2. Connect it to a device and play some music.
  3. Slowly walk away. If the connection becomes unstable after a few meters this earbud likely has a disconnected antenna.
  4. repeat with the other one.
    1. Fix unstable bluetooth connection, Heating up the lid: step 1, image 1 of 1
      • Heat up the lid by leaving the earbud upside down on a hotplate at ~80°C for ~1min. A 3d printers hotbed works well for this.
      • A heat gun should also work as well.
      Ask FixBot
    2. Fix unstable bluetooth connection, Breaking the seal: step 2, image 1 of 1
      • The earbuds are glued shut.
      • Put some cloth around the earbud and put it in a vice like shown.
      • Pliers might work too if you don't have a vice but it's not recommended.
      • Slowly close the vice until there is a cracking sound or a gap forms in the seam.
      Ask FixBot
    3. Fix unstable bluetooth connection, Removing the lid: step 3, image 1 of 1
      • Heat up the lid again before continuing.
      • Separate the 2 halfs using one of the opening picks.
      • Make sure not to press the pick more then ~1mm into the case to avoid damaging anything on the PCB.
      • Slowly lift up the outer half after cracking the seal around the whole earbud. Slowly pull them apart as there is some flexible adhesive on 2 internal pegs that takes a bit of time to "give up".
      Ask FixBot
    4. Fix unstable bluetooth connection, Secure the mic cover: step 4, image 1 of 1
      • The marked mic cover tends to easily get lost. It's best to take it of and store it with the top half until reassembly.
      Ask FixBot
    5. Fix unstable bluetooth connection, Scrape away old glue: step 5, image 1 of 1
      • Try to remove as much of the hard, clear glue on the outside edge to make sure the buds close nicely when reassembling them.
      • A precision rotary tool with a fine abrasive tip and/or a scalpel works best.
      Ask FixBot
    6. Fix unstable bluetooth connection, Remove old glue: step 6, image 1 of 1
      • Try to remove as much of the white glue as possible using a scalpel and/or tweezers.
      • Putting the lid back on the hotplate or a bit of Isopropanol can help softening it.
      Ask FixBot
    7. Ask FixBot
    1. Fix unstable bluetooth connection, Lift antenna: step 8, image 1 of 2 Fix unstable bluetooth connection, Lift antenna: step 8, image 2 of 2
      • Lift up the contact area of the antenna with a scalpel.
      • Be especially careful when pushing it around the mic port(marked in red) that's beneath it.
      Ask FixBot
    2. Fix unstable bluetooth connection, Add piece of foam: step 9, image 1 of 1
      • Put a thin piece of foam the size of the contact area behind it.
      Ask FixBot
    3. Fix unstable bluetooth connection, Push the antenna back in place: step 10, image 1 of 1
      • Fold the contact are back down.
      Ask FixBot
Author
with
Byte Hoarder
535 Reputation
4 Guides authored
0 Guide Comments
Past 24 Hours: 8
Past 7 Days: 40
Past 30 Days: 135
All Time: 775
