Fitbit Blaze Battery Replacement
  1. Fitbit Blaze Battery Replacement, Wristband: step 1, image 1 of 2 Fitbit Blaze Battery Replacement, Wristband: step 1, image 2 of 2
    • Locate the front LCD screen on your device.
    • Fitbit logo should appear in the bottom center of the screen.
  2. Fitbit Blaze Battery Replacement: step 2, image 1 of 1
    • Push the screen out through the back of the metal ring enclosure.
    • Use a small amount of force on screen to prevent damage. Use other hand to catch screen.
  3. Fitbit Blaze Battery Replacement: step 3, image 1 of 3 Fitbit Blaze Battery Replacement: step 3, image 2 of 3 Fitbit Blaze Battery Replacement: step 3, image 3 of 3
    • Locate the metal pin behind the wristband located on the edge of metal ring.
    • Insert the pointed end of the metal spudger into the pin hold and push it into the blue rectangle enclosure.
    • Use a small amount of force to avoid damaging the pins.
    • Remove wristband.
  4. Fitbit Blaze Battery Replacement, Battery: step 4, image 1 of 3 Fitbit Blaze Battery Replacement, Battery: step 4, image 2 of 3 Fitbit Blaze Battery Replacement, Battery: step 4, image 3 of 3
    • Place device screen face down and locate the four screws attaching the back cover.
    • Use a T3 torx head or T3 torx screwdriver to remove the four screws.
  5. Fitbit Blaze Battery Replacement: step 5, image 1 of 3 Fitbit Blaze Battery Replacement: step 5, image 2 of 3 Fitbit Blaze Battery Replacement: step 5, image 3 of 3
    • Grab the back, lift and open like a book to expose the motherboard. Locate the ribbon connector on the left.
    • Use a plastic spudger tool on the ribbon connected from the heart rate monitor to the motherboard.
    • Insert and lift the plastic opening tool to release the ribbon.
    • Only a small force when lifting the plastic connector is needed to avoid damage.
  6. Fitbit Blaze Battery Replacement: step 6, image 1 of 3 Fitbit Blaze Battery Replacement: step 6, image 2 of 3 Fitbit Blaze Battery Replacement: step 6, image 3 of 3
    • Separate the back and set aside, locate the three screws attaching the motherboard.
    • Use a PH000 head or a PH000 screwdriver to remove the three screws.
  7. Fitbit Blaze Battery Replacement: step 7, image 1 of 3 Fitbit Blaze Battery Replacement: step 7, image 2 of 3 Fitbit Blaze Battery Replacement: step 7, image 3 of 3
    • Use a plastic spudger tool on the ribbons connected to the motherboard.
    • Insert the tool under the ribbon and lift to release the connection.
  8. Fitbit Blaze Battery Replacement: step 8, image 1 of 3 Fitbit Blaze Battery Replacement: step 8, image 2 of 3 Fitbit Blaze Battery Replacement: step 8, image 3 of 3
    • Lift and push the motherboard to the side to uncover the 167mAh battery.
    • Use a plastic spudger tool to pry out the battery from its adhesive plastic underneath.
    • Lift up and pull downward to remove battery. Switch to the top portion of the battery and push downward to pry out battery.
  9. Fitbit Blaze Battery Replacement: step 9, image 1 of 3 Fitbit Blaze Battery Replacement: step 9, image 2 of 3 Fitbit Blaze Battery Replacement: step 9, image 3 of 3
    • Flip the motherboard backwards and locate the metal pins from the battery soldered to the board.
    • Desolder the connection to remove the battery, desolder the battery connector itself if desired as well.
    • Follow this guide on how to solder and desolder connectors Soldering Guide
    • Excessive heat will damage the components, so do not apply the soldering iron to the component for long amounts of time.
Adrian Borrego
2,242 Reputation
5 Guides authored
USF Tampa, Team S3-G3, Sullivan Spring 2017 Member of USF Tampa, Team S3-G3, Sullivan Spring 2017
USFT-SULLIVAN-S17S3G3
4 Members
15 Guides authored
Past 24 Hours: 5
Past 7 Days: 33
Past 30 Days: 196
All Time: 131,136
