Up to 20% off select tools
Felco Pruners Disassembly
Views: 4K
View statistics:
Past 24 Hours:
3
Past 7 Days:
33
Past 30 Days:
151
All Time:
3,961
Comments: 2
2 guide comments.
Go to guide comments
Completed: 1
1 person has marked this guide "completed." Will you be next?
Favorites: 2
2 people have favorited (and subscribed to) this guide. Will you be next?
Time Required: 15 minutes
Difficulty: Very easy
Community-Contributed Guide
Introduction
Go to step 1 ↓
These scissors require a little maintenance. The blade must be sharpened, rust marks removed and the joint lubricated.
    1. Felco Pruners Disassembly, Various types available: step 1, image 1 of 1
      • There are several types - e.g. also for left-handers, here a Felco Nr 4 is shown.
      Ask FixBot
    2. Felco Pruners Disassembly, Release mother: step 2, image 1 of 1
      • First, the upper nut SW 13 is released, then the scissors is turned over.
      • The spring can be easily removed.
      Ask FixBot
    3. Felco Pruners Disassembly, Release screw from below: step 3, image 1 of 1
      • Now the hinge screw can be unscrewed. Here SW 14 is used Next to it lies the spring and the lock nut.
      • Now the scissors can be completely disassembled.
      • The blade is pinned with three bolts in the handle half and usually dissolves easily.
      Ask FixBot
    4. Felco Pruners Disassembly, The items: step 4, image 1 of 1
      • The scissors are disassembled. We see the pivot nut, the hinge screw, the spring, the two handles and the blade.
      Ask FixBot
      • The blade is ground on one side. Sharpen the beveled edge with about 15 degrees, only deburr the straight edge with a maximum of 5 degrees.
      • The parts should be free from rust and freshly oiled or greased.
      Ask FixBot
Repeat the steps in order to reassemble your device.
Special thanks to these translators:
de en
100%
These translators are helping us fix the world! Want to contribute?
Start translating ›
Author
with
VauWeh
348,596 Reputation
321 Guides authored
2 Guide Comments
Does the fixed bolt need Locktight or thread locker applied to its thread to stop it coming loose in operation?
Nicholas Little - Reply Share
I did not use a thread locker and ist works until today.
VauWeh - Reply Share
Past 24 Hours: 3
Past 7 Days: 33
Past 30 Days: 151
All Time: 3,961
