Shop the Holiday Gift Guide
FSC Board Removal
View statistics:
Past 24 Hours:
6
Past 7 Days:
17
Past 30 Days:
33
All Time:
124
Comments: 7
7 comments on steps.
Completed: 0
Favorites: 0
Time Required: No estimate
Difficulty: Moderate
Prerequisite Only
This is a prerequisite-only guide! This guide is part of another procedure and isn’t meant to be used alone.
FSC Board Removal
Introduction
Go to step 1 ↓
This guide shows how to remove the FSC board in the Steam Controller (2nd Gen, 2026).
Tools
    1. FSC Board Removal, Before you begin: step 1, image 1 of 3 FSC Board Removal, Before you begin: step 1, image 2 of 3 FSC Board Removal, Before you begin: step 1, image 3 of 3
      • Let your controller's battery drain below 25% before starting this repair.
      • Unplug all cables and accessories from the controller, including the Steam Controller Puck.
      • During your repair, it can be helpful to lay the Steam Controller on a clean, soft cloth for stabilization and to prevent scratches.
      Ask FixBot
    2. FSC Board Removal, Remove the back cover screws: step 2, image 1 of 2 FSC Board Removal, Remove the back cover screws: step 2, image 2 of 2
      Tool used on this step:
      TR6 Torx Security Screwdriver
      $5.99
      Buy
      Ask FixBot
    3. FSC Board Removal, Remove the back cover: step 3, image 1 of 2 FSC Board Removal, Remove the back cover: step 3, image 2 of 2
      • Remove the back cover.
      Ask FixBot
    1. FSC Board Removal, Remove the battery: step 4, image 1 of 3 FSC Board Removal, Remove the battery: step 4, image 2 of 3 FSC Board Removal, Remove the battery: step 4, image 3 of 3
      • If your battery is swollen, take appropriate precautions. Never reinstall a swollen battery—replace it with a new one.
      • Lift the right edge of the battery to remove it.
      • During reassembly, first slide the left side of the battery into place so its connector is fully seated. Then, press the right side into place to secure it.
      Ask FixBot
    1. FSC Board Removal, Remove the mounting bracket screws: step 5, image 1 of 2 FSC Board Removal, Remove the mounting bracket screws: step 5, image 2 of 2
      • During the rest of your repair, don't forcefully push the controller down onto your work surface—you may damage the thumbsticks and trackpads.
      • Use a T6 Torx screwdriver to remove the four 7.4 mm‑long screws securing the battery mounting bracket.
      Ask FixBot
    2. FSC Board Removal, Remove the mounting bracket: step 6, image 1 of 2 FSC Board Removal, Remove the mounting bracket: step 6, image 2 of 2
      Ask FixBot
    1. FSC Board Removal, Disconnect the rumble motors: step 7, image 1 of 3 FSC Board Removal, Disconnect the rumble motors: step 7, image 2 of 3 FSC Board Removal, Disconnect the rumble motors: step 7, image 3 of 3
      • Don't pull on the rumble motor's delicate wires—they're easily damaged. Be careful not to pinch the wires with your tweezers, and only pull on the connector itself.
      • Firmly grip the short edges of one rumble motor connector with a pair of tweezers and pull straight up to disconnect it
      • Grip the tweezers as close to the tip as possible to get a better hold on the connector.
      Ask FixBot
    2. FSC Board Removal: step 8, image 1 of 3 FSC Board Removal: step 8, image 2 of 3 FSC Board Removal: step 8, image 3 of 3
      • Repeat to disconnect the other rumble motor.
      Ask FixBot
    3. FSC Board Removal, Disconnect the interconnect cable: step 9, image 1 of 3 FSC Board Removal, Disconnect the interconnect cable: step 9, image 2 of 3 FSC Board Removal, Disconnect the interconnect cable: step 9, image 3 of 3
      • Be careful not to damage any of the small, surface-mounted components on the main board.
      • Use a spudger to lift the hinged locking flap on the interconnect cable ZIF connector, located on the bottom edge of the main board.
      Ask FixBot
    4. FSC Board Removal: step 10, image 1 of 2 FSC Board Removal: step 10, image 2 of 2
      • Use tweezers to grip the cable by its plastic pull tab and slide it out of the socket.
      Ask FixBot
    5. FSC Board Removal, Remove the main board screws: step 11, image 1 of 3 FSC Board Removal, Remove the main board screws: step 11, image 2 of 3 FSC Board Removal, Remove the main board screws: step 11, image 3 of 3
      • Use a T6 Torx screwdriver to remove the three 7.4 mm‑long screws securing the main board.
      • When reinstalling the screws, raise the controller so the thumbsticks aren't pressed against your work surface—pressure on the thumbsticks can cause improper alignment and seating.
      Ask FixBot
    6. FSC Board Removal, Remove the main board: step 12, image 1 of 3 FSC Board Removal, Remove the main board: step 12, image 2 of 3 FSC Board Removal, Remove the main board: step 12, image 3 of 3
      • Pull the main board down so the top corners clear the triggers.
      • You should be able to remove the board without removing the triggers. If you're having trouble, check out this guide to remove them.
      • Remove the main board, guiding the thumbsticks through their cutouts.
      • During reassembly, make sure the two rumble motor wires don't get trapped underneath the board. Use the four alignment posts to ensure the board is properly positioned.
      Ask FixBot
    7. FSC Board Removal, Rubber piece information: step 13, image 1 of 3 FSC Board Removal, Rubber piece information: step 13, image 2 of 3 FSC Board Removal, Rubber piece information: step 13, image 3 of 3
      • The rubber piece above the status LED may have been dislodged when removing the main board.
      • If the rubber piece is out of place, remove it and set it aside.
      • During reassembly, place the rubber piece so the two tabs are on the bottom and towards the back.
      Ask FixBot
    1. FSC Board Removal, Remove the hinge pin: step 14, image 1 of 3 FSC Board Removal, Remove the hinge pin: step 14, image 2 of 3 FSC Board Removal, Remove the hinge pin: step 14, image 3 of 3
      • With one hand, fully depress one trigger.
      • Don't let go of the trigger, or it will eject and you may lose its spring.
      • With your free hand, use tweezers to pull the hinge pin straight out and remove it.
      • During reassembly, hold the trigger down and slide the pin through both hinge holes—the pin will stop sliding once it's fully inserted. Test the trigger to ensure the pin was properly installed.
      • When correctly inserted, the pin's end will be alinged with the white rectangle on the board (labeled PIN)—there should be no wobble.
      Ask FixBot
    2. FSC Board Removal, Remove the trigger: step 15, image 1 of 3 FSC Board Removal, Remove the trigger: step 15, image 2 of 3 FSC Board Removal, Remove the trigger: step 15, image 3 of 3
      • Lift the trigger straight up and remove it.
      • Remove the spring and store it in a safe place for reassembly.
      • The spring will either stick to the trigger's magnet or stay on its post.
      Ask FixBot
    3. FSC Board Removal, Remove the other trigger: step 16, image 1 of 3 FSC Board Removal, Remove the other trigger: step 16, image 2 of 3 FSC Board Removal, Remove the other trigger: step 16, image 3 of 3
      • Repeat to remove the other trigger.
      Ask FixBot
    4. FSC Board Removal, Reassembly information: step 17, image 1 of 3 FSC Board Removal, Reassembly information: step 17, image 2 of 3 FSC Board Removal, Reassembly information: step 17, image 3 of 3
      • During reassembly, follow this step to install the triggers.
      • Place one of the trigger springs over its post on the controller.
      • Put the trigger in place, making sure the spring goes over both of its posts (one on the controller and one on the trigger) and that the hinge holes are all aligned.
      • Hold the trigger down and slide the pin through both hinge holes—the pin will stop sliding once it's fully inserted.
      • If you're having trouble, make sure you're installing the trigger on the correct side.
      • Test the trigger to ensure the pin was properly installed.
      • Repeat to install the other trigger.
      Ask FixBot
    5. FSC Board Removal, Remove the midframe screws: step 18, image 1 of 2 FSC Board Removal, Remove the midframe screws: step 18, image 2 of 2
      • Use a T6 Torx screwdriver to remove the eleven 7.4 mm‑long screws securing the midframe.
      • When removing the screw in the center of the controller, be careful not to slip and damage the flexible button circuit.
      Ask FixBot
    6. FSC Board Removal, Remove the midframe: step 19, image 1 of 3 FSC Board Removal, Remove the midframe: step 19, image 2 of 3 FSC Board Removal, Remove the midframe: step 19, image 3 of 3
      • Lift the midframe straight up and remove it.
      • The buttons and their silicone membranes are now sitting loose in their recesses. Don't flip the front shell or the buttons will fall out. Optionally, remove the membranes and buttons and set them aside.
      • During reassembly:
      • If you removed the buttons and their membranes:
      • Make sure the rubber button dampeners (that surround the button recesses) are pushed down and fully seated against the shell.
      • Install the buttons and membranes, using the alignment tabs to orient each button in its recess. Each one is keyed for proper location and orientation.
      • Check the two large silicone button membranes to make sure they're aligned properly and fully seated—if they aren't, button presses may feel off or not register.
      • Use the alignment posts to ensure the midframe is in the right position.
      Ask FixBot
    7. FSC Board Removal, Check for the Steam button membrane: step 20, image 1 of 2 FSC Board Removal, Check for the Steam button membrane: step 20, image 2 of 2
      • Check if the Steam button's silicone membrane stuck to the button circuit on the midframe.
      • If it did, either put the membrane back in place or set it aside.
      Ask FixBot
    1. FSC Board Removal, Disconnect the trackpad cables: step 21, image 1 of 2 FSC Board Removal, Disconnect the trackpad cables: step 21, image 2 of 2
      • Use the flat end of a spudger to lift the hinged, locking flap on one of the trackpad ZIF connectors.
      Ask FixBot
    2. FSC Board Removal: step 22, image 1 of 2 FSC Board Removal: step 22, image 2 of 2
      Ask FixBot
    3. FSC Board Removal: step 23, image 1 of 3 FSC Board Removal: step 23, image 2 of 3 FSC Board Removal: step 23, image 3 of 3
      • Repeat to disconnect the other trackpad cable.
      Ask FixBot
    4. FSC Board Removal, Remove the FSC board screws: step 24, image 1 of 2 FSC Board Removal, Remove the FSC board screws: step 24, image 2 of 2
      • Use a T5 Torx screwdriver to remove the four 6.0 mm‑long screws securing the FSC board.
      Ask FixBot
    5. FSC Board Removal, Remove the FSC board: step 25, image 1 of 3 FSC Board Removal, Remove the FSC board: step 25, image 2 of 3 FSC Board Removal, Remove the FSC board: step 25, image 3 of 3
      • Remove the FSC board.
      • Use the alignment pegs to ensure the board is correctly positioned.
      Ask FixBot
Finish Line
Spencer Day
210,389 Reputation
1,265 Guides authored
0 Guide Comments
Past 24 Hours: 6
Past 7 Days: 17
Past 30 Days: 33
All Time: 124
