Press and hold down the black button below the handle while pulling the pole out.
Use a #2 Phillips head screwdriver to remove six 13.9mm screws from the side of the motor housing (top half) as shown.
Remove two 14.1mm screws from the front face of the housing. You are now all set to open the housing.
Once the housing is open, locate the solid chrome plated piece at the front end of the extendable pole.
On the side of the motor housing which does not hold the engine, find the center track which runs along the inside of the housing.
Re-insert the chrome plated piece into the center track.
