This translation was generated by a machine and has not been reviewed by a person yet. Speak this language? Review it.
Community-Contributed Guide
Needs More Images
A few more images would make this guide's procedures crystal clear.
Introduction
Go to step 1 ↓This guide presents the precautions, preliminary maintenance, and first steps for a gradual E85 conversion on a Renault Twingo III Phase 1 (2014-2019). Read all risks and known issues before beginning.
Disclaimer
The use of E85 may be illegal in your case, particularly if the vehicle does not have an approved conversion kit installed by an authorized professional or if the registration document is not up to date. Long-term reliability is not guaranteed.
Reliability not guaranteed in the long term. (written with 50,000km at 100% E85 summer and winter, 1.0 SCe 70 or H4D)
False values of 25 to 30% on the dashboard: fuel gauge, consumption, estimated range. See wiki.
Impeccable and regular maintenance is essential. Certain existing issues and sensitivity to sensor defects, elements of the injection/ignition system, seem largely amplified. See wiki.
Cleaning of the MAP sensor, throttle body, and intake thermometer.
Fill the tank, almost empty, with a sufficiently small amount of E85, so that it can be easily drowned with gasoline if problems are encountered.
Adopt a gentle approach: the calculator only works with short-term values and risks not being precise enough if too much is asked of it.
Drive at maximum on the regulator to allow the calculator to adapt to fixed conditions and effectively modify long-term values.
To reassemble your device, follow the instructions in reverse order.
3 other people completed this guide.
Special thanks to these translators:
100%
redratchet21 is helping us fix the world! Want to contribute?
Start translating ›
14 Guide Comments
Bonjour Antonio,
J'ai suivi plusieurs de tes tutos sur la Twingo 3 et je te remercie pour ton travail détaillé.
Je cherche à installer un catch can sur ma Twingo 3 mais je ne sais vraiment pas où le raccorder ni l'installer au niveau du moteur.
Peux-tu me donner des conseils et, si possible, des photos de ton installation ?
Merci pour ton retour.
Cordialement.
Bonjour Antonio,
Merci pour tes nombreuses indications et tuto. J'envisage de passer la Twingo à l'E85 mais j'aimerai avoir quelques infos avant pour bien préparer les choses.
1- Installation d'un catch can (pour récupérer les vapeurs d'huile).
Où as tu acheté le tien ? Site chinois ? Quel diamètre de connecteur conseilles-tu ?
2- Bougies plus résistantes ?
J'ai vu qu'il était conseillé d'utiliser des bougies iridium ? J'ai acheté un pack (réf. N64 - VR7SI332S de Bosch)
3- Passage a l'éthanol
Si j'ai bien compris, tu conseilles une adaptation progressive : 25%, puis 50%, 75% et voir jusqu'à 100%.
Peux-tu indiquer tes valeurs de correction à long terme ? Sur ma Twingo III (Sce 69cv) je suis à 33,59% avec de l'E10.
Merci d'avance !
@nicolas30898 Hello,
0. Alors, avant tout ça ton huile. C'est le + important avec tes bougies.
1. Mon installation de catch-can c'est le genre d'installation que j'ai fait un jour (en 2023) pour tester. Tu sais, celle où te dis que c'est "temporaire" et qui finalement reste pendant des années. Je ne pouvais pas faire entièrement propre à cette époque, par manque d'information et de budget. Je n'en suis pas totalement fier mais bon, elle marche vraiment bien !
J'ai une catch can un peu cheap, je compte remplacer le filtre en laiton au niveau de la sortie de la mienne pour un avec + de surface bientôt. Je voudrais refaire mon installation de catch-can proprement à terme, peut-être avec un tuto, sinon en reprenant au moins proprement tous les diamètres de conduites et les types de connecteurs rapides pour faire un truc qui fasse "OEM plus" et qui soit réversible facilement.
2. Les VR7SI332S c'est celles avec lesquelles j'ai quasiment toujours, c'est très bien (je n'ai pas essayé les NGK).
3. Progressif c'est dans le doute et parce que c'est mieux de faire bien les choses.
Ma "vraie conversion" ça été de retirer mon boitier E85 un soir parce que je m'ennuyais et de démarrer le moteur, juste pour voir si ça marchait. Donc essentiellement faire un zéro 100% instantanné. C'est à la fois l'idée la plus stupide du monde, mais aussi l'une des idées les plus brillantes que j'ai pu avoir sur ma Twingo.
Mes LTFT sont maxed-out. Je suis à 98.4% (environ, la valeur MAX) avec en permanence au moins 10% de STFT sur 100% d'E85 en été.
Même avec ces chiffres, il n'existe aucune condition dans laquelle j'ai réussi à faire tourner mon moteur pauvre (lambda >1.00), hors de la tolérance normale liée au contrôle du catalyseur. Je tourne riche quand il le faut, à la valeur de consigne lambda donnée en OBD standard.
Par contre ce n'est pas 100% parfait : il existe des cas où je ressens l'imprécision du calculateur. Mais c'est infiniment mieux que si tu roulais avec un boitier. Quelle horreur mon boitier avant, wah.
