This translation was generated by a machine and has not been reviewed by a person yet. Speak this language? Review it.
Spark plugs and/or ignition coils replacement/cleaning
Featured Document
    1. Spark plugs and/or ignition coils replacement/cleaning, Accessing the engine hood: step 1, image 1 of 1
      • Open the trunk.
      • Remove the trunk carpets.
      Ask FixBot
    2. Spark plugs and/or ignition coils replacement/cleaning, Acessing the engine compartment: step 2, image 1 of 1
      • Unscrew the 6 screws by hand or with a T50 socket.
      • Lift and set aside the engine hood.
      Ask FixBot
    1. Spark plugs and/or ignition coils replacement/cleaning, Extracting ignition coils: step 3, image 1 of 3 Spark plugs and/or ignition coils replacement/cleaning, Extracting ignition coils: step 3, image 2 of 3 Spark plugs and/or ignition coils replacement/cleaning, Extracting ignition coils: step 3, image 3 of 3
      • Disconnect and put aside the oil vapor duct.
      • Disconnect the ignition coils' connector.
      • Unscrew each 8mm bolt of the 3 ignition coils.
      • Gently extract the ignition coils.
      Ask FixBot
    2. Spark plugs and/or ignition coils replacement/cleaning, Extracting the spark plugs: step 4, image 1 of 3 Spark plugs and/or ignition coils replacement/cleaning, Extracting the spark plugs: step 4, image 2 of 3 Spark plugs and/or ignition coils replacement/cleaning, Extracting the spark plugs: step 4, image 3 of 3
      • Unscrew and extract the spark plugs using a 14mm spark plug socket.
      • Clean off and/or dust off the debris in the zone to avoid contamination in the cylinders.
      • The Nickel/Copper spark plug shown (Bosch VR8SC+) has around 25.000km on it, using 100% E85. It is heavily contaminated by additives present in fuel at service stations.
      • Typical color of MMT contamination: (Methylcyclopentadienyl)manganese tricarbonyl, an organo-metallic fuel additive that can, according to ACEA reports and my own experience, render spark plugs unusable sometimes in less than 10,000km.
      • The presence of metallic additives in fuel must be indicated at the pump by a label, as required by European directives and French law.
      Ask FixBot
    3. Spark plugs and/or ignition coils replacement/cleaning, Electrode Calibration: step 5, image 1 of 1
      • Some spark plugs are known to have incorrect gaps, which are set too high by the factory. Spark plugs can also become misadjusted during shipping. Examples: Denso IXEH20TT: 1.00mm from the factory. Many copper spark plugs: 0.90mm from the factory.
      • Check and adjust the gap using shim sets. Maximum gaps for 95RON E10: 0.70mm for the H4BT, 0.80mm for the H4D.
      • E85: Reducing the gaps may be beneficial or even necessary, depending on the spark plug type and engine. See the wiki for more details. You should primarily base your decision on idle quality and the linearity of engine response; any hitches or hesitations may indicate an improper gap.
      • Idle quality: must be checked at 800 RPM. Only blame the gap once you have thoroughly cleaned the following: MAP sensor, injectors, and throttle body.
      • Indexing (start of thread): Variable (0°, 90°, 180°, or 270°) on various spark plug brands and models, including, among others, the Bosch VR8SC and VR7SI332S.
      • Optional: Draw a red line with a marker to mark the position of the open side of the spark plug if indexing is desired later. You can also draw a black line to mark the closed side and number the spark plugs.
      • Side-gap: You can optionally side-gap your spark plugs, but only if you have a Dremel-type tool. Understand and understand the benefits based on your driving style. This operation may be beneficial, but it significantly reduces the spark plug's lifespan and accelerates electrode erosion.
      • As a precaution (without scientific basis), do not write anything with a marker on the ceramic of the spark plugs in contact with the coils.
      Ask FixBot
    4. Spark plugs and/or ignition coils replacement/cleaning, Installating the new spark plugs: step 6, image 1 of 3 Spark plugs and/or ignition coils replacement/cleaning, Installating the new spark plugs: step 6, image 2 of 3 Spark plugs and/or ignition coils replacement/cleaning, Installating the new spark plugs: step 6, image 3 of 3
      • The RTA (French Revue Technique Automobile) and spark plug manufacturers advise not to grease the spark plug's thread, as it may alter the tightening torque.
      • Torque the new spark plug by hand using a 14mm spark plug socket at 24 N · m, or until it reaches the stop.
      • Optional: If specific indexing is desired (e.g., open side facing the intake), note the current spark plug position, unscrew it, and add calibrated washers accordingly to create rotational retard.
      • Tightening to the correct torque adds a predictable ~180° of rotation compared to hand-tightening a new spark plug.
      • Verify and, if necessary, adjust the spark plug gap to the model's spec. The spark plug wells of all 3 cylinders appear to be identically bored on the H4D-400. A spark plug that is at +90° on cylinder 1 will necessarily be at +90° on cylinders 2 and 3. Just double-check.
      • Tighten the spark plug to the mandatory torque of 24 Nm (RTA) or 23 Nm (Bosch).
      • Never apply a 180° torque to a spark plug that has already been used or torqued!
      • Thread: M12*1.25, 14mm hex key.
      Ask FixBot
    5. Spark plugs and/or ignition coils replacement/cleaning, Reinstalling the ignition coils: step 7, image 1 of 2 Spark plugs and/or ignition coils replacement/cleaning, Reinstalling the ignition coils: step 7, image 2 of 2
      • Generously apply dielectric grease(silicone grease) inside the coil extension. Do not apply any other type of grease (e.g., lithium grease) as it is conductive and could cause serious problems.
      • Dielectric grease helps limit current leakage and reduces voltage/arc power drops compared to dry installation. This is particularly important with E85 fuel where coil power seems to be a limiting factor.
      • Reposition the ignition coils onto the spark plugs until they are fully seated.
      • Tighten the single 8mm screw on each coil to a torque of 10 Nm.
      • Reconnect the ignition coil connectors.
      Ask FixBot
Congratulations! You replaced your spark plugs/ignition coils!
The idle is still not satisfactory? Then it might be time to clean the MAP sensor, injector tips, and throttle body :)
9 other people completed this guide.
Special thanks to these translators:
fr en
100%
These translators are helping us fix the world! Want to contribute?
Start translating ›
AntonioTwingo
8,153 Reputation
45 Guides authored
2 Guide Comments
Coucou Antonio, recois-tu mes mails ?
Fra San - Reply Share
Coucou, je reçois bien tes mails à l'adresse suivante:
antoniotwingo@proton.me
AntonioTwingo - Reply Share
Past 24 Hours: 7
Past 7 Days: 42
Past 30 Days: 233
All Time: 7,713
