Introduction
This guide shows how to remove the paper eject frame assembly Constant paper jams might be caused by a faulty paper eject frame assembly. This process requires the knowledge of how to use basic tools.
Turn off the printer.
Disconnect all data connections coming into the printer such as USB, networkd cables, firewire, etc. as well as removing the power cord.
Locate the IEEE cover in the back.
Gently slide the cover to the right to unlatch, then pull to remove it.
Using a Phillips #2 screwdriver, remove the four 10 mm screws shown.
Remove the 6 mm screw that holds the rear housing in place.
Insert a plastic opening tool into the cutouts of the lower housing.
Release the two tabs of the side housing by lifting the tool in an upward motion.
Remove the side housing by pulling it outwards.
Remove the four 10 mm Phillips #2 screws from the sides of the printer.
Remove the three 6 mm Phillips #2 screws.
Start by emptying the ink tube.
Hold the left side of the ink tube in your hand.
Pull the sides of the tube apart and empty the waste.
Remove the first three 10 mm screws that hold the printer mechanism in place using a Phillips #2 screwdriver.
Remove the other three 10mm screws that secure the printer mechanism using a Phillips #2 screwdriver. The locations of the screws are pictured.
The printer mechanism is located on the lower housing.
Remove the mechanism by holding the handles and lifting upwards.
Remove the CD-R unit housing. Release the two attaching points to the tray base and then pull out the unit diagonally one side at a time.
Detach the left frame support plate. Start by removing the two 6mm screws that secure it and then pull it out by hand.
