Introduction
This guide shows how to remove the paper eject frame assembly Constant paper jams might be caused by a faulty paper eject frame assembly. This process requires the knowledge of how to use basic tools.
Turn off the printer.
Disconnect all data connections coming into the printer such as USB, networkd cables, firewire, etc. as well as removing the power cord.
Locate the IEEE cover in the back.
Gently slide the cover to the right to unlatch, then pull to remove it.
Using a Phillips #2 screwdriver, remove the four 10 mm screws shown.
Remove the 6 mm screw that holds the rear housing in place.
Insert a plastic opening tool into the cutouts of the lower housing.
Release the two tabs of the side housing by lifting the tool in an upward motion.
Remove the side housing by pulling it outwards.
Remove the four 10 mm Phillips #2 screws from the sides of the printer.
Remove the three 6 mm Phillips #2 screws.
Hold the ink tube and draw out the waste ink tube by pulling on both tubes in opposite directions.
Using the #2 Phillips screwdriver, remove the last three 10mm screws securing the printer mechanism.
Remove the CD-R unit housing by releasing the two attaching points to the tray base.
Pull it outwards diagonally one side at a time.
Remove the left frame support plate by removing the two 6mm screws that secure it.
Pull it out by hand to free it.
