Ematic eGlide 4 Side Button Array Replacement
  1. Ematic eGlide 4 Side Button Array Replacement, Rear Panel: step 1, image 1 of 1
    • Remove the 4.6mm Phillips #00 screw at the base of the device.
  2. Ematic eGlide 4 Side Button Array Replacement: step 2, image 1 of 1
    • Slide the rear panel away from the base parallel to the screen.
  3. Ematic eGlide 4 Side Button Array Replacement: step 3, image 1 of 2 Ematic eGlide 4 Side Button Array Replacement: step 3, image 2 of 2
    • Carefully remove the speakers from the rear panel.
    • Pull the speakers off of the rear panel.
  4. Ematic eGlide 4 Side Button Array Replacement, Side Button Array: step 4, image 1 of 1
    • Remove the 3 Phillips #00 4.5 mm screws from the side button array.
  5. Ematic eGlide 4 Side Button Array Replacement: step 5, image 1 of 2 Ematic eGlide 4 Side Button Array Replacement: step 5, image 2 of 2
    • Slide the grey ribbon wire connector clip away from the ribbon wire port on the motherboard using the pointed tip of a spudger. This process will unclip the wire from the motherboard to release connection.
    • You do not need to fully disconnect the ribbon wire clip from the ribbon wire port: the clip will stay attached in a loose fit.
    • Remove the ribbon wire from the ribbon wire port on the motherboard.
  6. Ematic eGlide 4 Side Button Array Replacement: step 6, image 1 of 1
    • Remove the side button array from the device.
Bailey Hughes
617 Reputation
6 Guides authored
Baylor, Team 5-8, Williams Spring 2015 Member of Baylor, Team 5-8, Williams Spring 2015
BU-WILLIAMS-S15S5G8
3 Members
6 Guides authored
Past 24 Hours: 2
Past 7 Days: 2
Past 30 Days: 7
All Time: 100
