EasySMX ESM-9100 Shoulder Buttons Replacement
  1. EasySMX ESM-9100 Shoulder Buttons Replacement, Bottom Case: step 1, image 1 of 1
    • Place the controller face down on a solid surface.
    • Use a Phillips #00 screwdriver to remove the seven 10 mm screws from the back cover.
    • The order does not matter.
  2. EasySMX ESM-9100 Shoulder Buttons Replacement: step 2, image 1 of 3 EasySMX ESM-9100 Shoulder Buttons Replacement: step 2, image 2 of 3 EasySMX ESM-9100 Shoulder Buttons Replacement: step 2, image 3 of 3
    • Use the iFixit opening tool to pry off the back cover and remove it to reveal the internal components.
    • Place the cover off to the side, then grab the circuit board and gently remove it from the front cover.
    • Be careful when removing the back cover, the components in this controller are loosely attached and can fall out easily.
  3. EasySMX ESM-9100 Shoulder Buttons Replacement, L/R Buttons: step 3, image 1 of 3 EasySMX ESM-9100 Shoulder Buttons Replacement, L/R Buttons: step 3, image 2 of 3 EasySMX ESM-9100 Shoulder Buttons Replacement, L/R Buttons: step 3, image 3 of 3
    • Remove the L and R shoulder buttons from their sockets on the top case.
    • Avoid touching the receiver as this is the component that will let the controller know the button has been pressed.
To reassemble your device, follow these instructions in reverse order. Take your e-waste to an R2 or e-Stewards certified recycler.
2 other people completed this guide.
Alex Vala
837 Reputation
6 Guides authored
0 Guide Comments
Past 24 Hours: 2
Past 7 Days: 9
Past 30 Days: 40
All Time: 422
