EasySMX ESM-9100 Navigation Buttons Replacement
    1. EasySMX ESM-9100 Navigation Buttons Replacement, Bottom Case: step 1, image 1 of 1
      • Place the controller face down on a solid surface.
      • Use a Phillips #00 screwdriver to remove the seven 10 mm screws from the back cover.
      • The order does not matter.
      Ask FixBot
    2. EasySMX ESM-9100 Navigation Buttons Replacement: step 2, image 1 of 3 EasySMX ESM-9100 Navigation Buttons Replacement: step 2, image 2 of 3 EasySMX ESM-9100 Navigation Buttons Replacement: step 2, image 3 of 3
      • Use the iFixit opening tool to pry off the back cover and remove it to reveal the internal components.
      • Place the cover off to the side, then grab the circuit board and gently remove it from the front cover.
      • Be careful when removing the back cover, the components in this controller are loosely attached and can fall out easily.
      Ask FixBot
    1. EasySMX ESM-9100 Navigation Buttons Replacement, Navigation Buttons: step 3, image 1 of 2 EasySMX ESM-9100 Navigation Buttons Replacement, Navigation Buttons: step 3, image 2 of 2
      • Pull the back button out of the front cover.
      • Keep the controller face down while doing this to prevent the other buttons from falling out.
      Ask FixBot
    2. EasySMX ESM-9100 Navigation Buttons Replacement: step 4, image 1 of 2 EasySMX ESM-9100 Navigation Buttons Replacement: step 4, image 2 of 2
      • Pull the start button out of the front cover.
      Ask FixBot
    3. EasySMX ESM-9100 Navigation Buttons Replacement: step 5, image 1 of 2 EasySMX ESM-9100 Navigation Buttons Replacement: step 5, image 2 of 2
      • Pull the turbo button out from the front cover carefully.
      Ask FixBot
To reassemble your device, follow these instructions in reverse order. Take your e-waste to an R2 or e-Stewards certified recycler.
Alex Vala
858 Reputation
6 Guides authored
0 Guide Comments
Past 24 Hours: 2
Past 7 Days: 12
Past 30 Days: 57
All Time: 579
