EasySMX ESM-9100 Bottom Case Replacement
Prerequisite Only
This is a prerequisite-only guide! This guide is part of another procedure and isn’t meant to be used alone.
    1. EasySMX ESM-9100 Bottom Case Replacement, Bottom Case: step 1, image 1 of 1
      • Place the controller face down on a solid surface.
      • Use a Phillips #00 screwdriver to remove the seven 10 mm screws from the back cover.
      • The order does not matter.
      Ask FixBot
    2. EasySMX ESM-9100 Bottom Case Replacement: step 2, image 1 of 3 EasySMX ESM-9100 Bottom Case Replacement: step 2, image 2 of 3 EasySMX ESM-9100 Bottom Case Replacement: step 2, image 3 of 3
      • Use the iFixit opening tool to pry off the back cover and remove it to reveal the internal components.
      • Place the cover off to the side, then grab the circuit board and gently remove it from the front cover.
      • Be careful when removing the back cover, the components in this controller are loosely attached and can fall out easily.
      Ask FixBot
Sarah Westberg
43,062 Reputation
72 Guides authored
iFixit Member of iFixit
Staff
122 Members
72,401 Guides authored
0 Guide Comments
Past 24 Hours: 1
Past 7 Days: 4
Past 30 Days: 15
All Time: 138
