Dyson V7 Battery Replacement
Views: 2.3K
View statistics:
Past 24 Hours:
71
Past 7 Days:
333
Past 30 Days:
1,022
All Time:
2,324
Comments: 0
Go to guide comments
Completed: 0
Favorites: 0
Time Required: 15 - 30 minutes
Difficulty: Moderate
Video Guide This guide was transcribed from a YouTube video.
Introduction
Go to step 1 ↓
Use this guide to replace the battery in a Dyson V7 cordless vacuum. The battery, also called the battery pack or rechargeable battery, powers the vacuum’s motor. Replace it if the vacuum won’t turn on, won’t hold a charge, or has poor battery life. Use a replacement made for the Dyson V7, and match the specifications printed on the original battery.
Parts
Tools
      • Disconnect the vacuum from its charger and place it on a stable work surface.
      • Do not press the trigger at any time during service.
      • Keep fingers, hair, and loose clothing away from the motor opening while the bin and cowl are removed.
      Ask FixBot
      • Open the clear bin.
      • Remove the cowl from the bin assembly.
      • Remove the clear bin from the motor unit.
      • Set the bin and cowl aside so they can be reinstalled before testing the vacuum.
      Ask FixBot
      • Identify the battery pack at the base of the motor unit.
      • Locate the three Phillips screws that secure the battery to the motor unit.
      • Locate the screw in the handle above the battery.
      • Locate the two screws near the front of the battery bay.
      Ask FixBot
      • Use a Phillips #2 screwdriver to remove the three battery screws.
      • Keep the screwdriver fully seated in each screw head to avoid stripping it.
      Ask FixBot
      • Separate the battery pack from the motor unit.
      • Keep the battery terminals away from metal objects and liquids.
      Ask FixBot
      • Compare the replacement battery with the original battery before installing it.
      • Match the Dyson V7 specifications printed on the bottom of the original battery.
      • Do not install a battery that is swollen, leaking, hot, or damaged.
      Ask FixBot
      • Align the battery pack with the motor unit.
      • Slide the battery into the motor unit until the screw holes line up.
      • Use a Phillips #2 screwdriver to reinstall the three battery screws.
      • Tighten each screw until snug, but don’t overtighten or strip the screw heads.
      Ask FixBot
      • Reinstall the clear bin on the motor unit.
      • Reinstall the cowl.
      • Make sure the bin and cowl are fully seated before pressing the trigger.
      • Do not run the vacuum with the bin or cowl removed, because the motor opening is exposed.
      Ask FixBot
      • Press the trigger only after the battery, three screws, bin, and cowl are installed.
      • Run the vacuum briefly and confirm it powers on.
      • If the vacuum still doesn’t work, check that the battery, screws, bin, and cowl are fully seated.
      Ask FixBot
After installing a new battery, charge it to 100%, and keep charging it for at least two more hours. Use the vacuum until it shuts off because of a low battery, then charge it uninterrupted to 100%.
Recycle the old battery according to local lithium-ion battery rules. Take your e-waste to an R2 or e-Stewards certified recycler. Repair didn't go as planned? Ask our Answers community for help.
eCuration
478,744 Reputation
396 Guides authored
0 Guide Comments
Past 24 Hours: 71
Past 7 Days: 333
Past 30 Days: 1,022
All Time: 2,324
