Dyson DC35 Battery Replacement
Video Guide
This guide was transcribed from a YouTube video.
      • Pull the trigger and check whether the vacuum runs.
      • A dead battery commonly causes no response from the trigger and no green charge light.
      • Disconnect the charger and remove the vacuum from the charging area before working on it.
      • Don't open, puncture, crush, heat, or cut into the battery pack.
      • If the battery is swollen, hot, leaking, or damaged, stop and keep it away from flammable materials.
      Ask FixBot
      • Press the top lever to release the front assembly.
      • Separate the vacuum into two pieces.
      • Pull the air filter out of the front of the vacuum.
      • Let a washed filter dry completely before reinstalling it, as moisture can damage the motor.
      Ask FixBot
      • Use a Phillips screwdriver to remove the front battery screw from the opening near the filter.
      • Use a Phillips screwdriver to remove the rear battery screw from the back of the handle.
      • Keep the screws separate, as the longer screw goes in the rear hole during reassembly.
      Ask FixBot
      • Slide the battery out through the bottom of the handle.
      • Identify the old battery style before ordering or installing a replacement.
      • Choose a Type B battery if the old battery has a tab on top.
      • Choose a Type A battery if the old battery has no tab on top.
      • DC31, DC34, DC35, DC44, and DC45 models may look similar, so match the replacement to the removed battery.
      Ask FixBot
      • Insert the matching replacement battery up through the bottom of the handle.
      • Push the battery in until it sits flush in the handle and the screw holes align.
      • If the battery doesn't seat correctly, remove it and recheck whether the vacuum needs a type A or Type B battery.
      Ask FixBot
      • Insert the longer screw into the rear hole and tighten it with a Phillips screwdriver.
      • Place the front screw into the front hole near the filter opening.
      • Use needle nose pliers to start the front screw if it is hard to hold in position.
      • Tighten the front screw with a Phillips screwdriver until it is seated.
      • Don't over-tighten the screws, as the plastic housing can strip or crack.
      Ask FixBot
      • Reinsert the air filter with its small tab facing up.
      • Seat the lower end of the front assembly into the main body.
      • Press the top of the assembly together until it clicks into place.
      • Pull the trigger to confirm the vacuum runs.
      • Place the vacuum on the charger and check that the green charge light comes on.
      Ask FixBot
      • Recycle the old battery as lithium-ion e-waste according to local rules.
      • Don't cut the wires or open the battery case, as the cells and circuit board are soldered inside.
      • If the vacuum still won't run or the green charge light still won't come on, remove and reseat the replacement battery.
      • Confirm that the replacement battery matches the old type A or Type B battery.
      • If the problem remains, stop using the vacuum until the battery and charging system can be checked.
      Ask FixBot
After installing a new battery, charge it to 100%, and keep charging it for at least two more hours. Use the vacuum until it shuts off because of a low battery, then charge it uninterrupted to 100%.
Charge the new battery fully before regular use, and keep the filter clean and dry for best vacuum performance. Take your e-waste to an R2 or e-Stewards certified recycler. Repair didn't go as planned? Ask our Answers community for help.
eCuration
478,744 Reputation
396 Guides authored
0 Guide Comments
Past 24 Hours: 12
Past 7 Days: 56
Past 30 Days: 207
All Time: 333
