Dyson DC34 Battery Replacement
Video Guide
This guide was transcribed from a YouTube video.
      • Pull the trigger and watch for any response from the vacuum.
      • A dead battery is a common cause when nothing happens and the green charge light doesn't turn on.
      • Disconnect the vacuum from its charger before opening it.
      • Don't puncture, crush, heat, or open the lithium-ion battery pack.
      Ask FixBot
      • Press the top release lever to pop the vacuum open.
      • Separate the vacuum into two pieces.
      • Remove the air filter from the front of the vacuum.
      • Wash the air filter occasionally as part of regular maintenance, and let it dry fully before reinstalling it.
      Ask FixBot
      • Use a Phillips screwdriver to remove the screw near the filter opening.
      • Use a Phillips screwdriver to remove the screw at the back of the battery area.
      • Keep the screws separated because the longer screw goes in the back during reassembly.
      • Slide the old battery out of the bottom of the vacuum.
      Ask FixBot
      • Compare the old battery before ordering a replacement battery.
      • Choose a Type B battery if the old battery has a tab on top.
      • Choose an Type A battery if the old battery has no tab on top.
      • Search parts sellers or online marketplaces for a compatible Dyson DC34 battery that matches the old battery style.
      Ask FixBot
      • Slide the replacement battery up through the bottom of the vacuum.
      • Use a Phillips screwdriver to install the longer screw in the back screw hole.
      • Tighten the screw until it is secure, but don't overtighten it.
      Ask FixBot
      • Place the front screw into the screw hole near the filter opening.
      • Use needle nose pliers to hold the screw and line it up if it's hard to start.
      • Use a Phillips screwdriver to seat and tighten the front screw.
      Ask FixBot
      • Reinstall the air filter in the front of the vacuum.
      • Use the small tab on top of the filter to orient it correctly.
      • Fit the two vacuum pieces back together.
      • Press the top closed until it clicks.
      • Pull the trigger to confirm the vacuum works.
      Ask FixBot
      • If the replacement battery doesn't fit, remove it and compare the top tab with the old battery.
      • If the front screw won't start, hold it with needle nose pliers until it sits in the hole.
      • If the vacuum doesn't close, remove and reinstall the filter with its tab facing up.
      • If the vacuum still doesn't run after a matching battery is installed, the battery may not be the only fault.
      • Don't cut open or repair the old battery pack because the cells and circuit board are soldered together inside.
      Ask FixBot
After installing a new battery, charge it to 100%, and keep charging it for at least two more hours. Use the vacuum until it shuts off because of a low battery, then charge it uninterrupted to 100%.
Recycle the old battery responsibly at a battery recycling location or an e-waste recycler. Take your e-waste to an R2 or e-Stewards certified recycler. Repair didn't go as planned? Ask our Answers community for help.
eCuration
478,744 Reputation
396 Guides authored
0 Guide Comments
Past 24 Hours: 10
Past 7 Days: 58
Past 30 Days: 188
All Time: 288
