Dyson DC31 Battery Replacement
Video Guide
This guide was transcribed from a YouTube video.
      • Unplug the vacuum from the charger and make sure the trigger won't be pressed while you work.
      • Work on a clean, dry surface away from liquids, heat, and loose metal objects.
      • Do not puncture, crush, open, or short the battery pack; replace it as a complete battery pack.
      • A dead battery is a common cause when the trigger does nothing or the green charge light no longer comes on.
      Ask FixBot
      • Press the top lever to release the front section of the vacuum.
      • Pull the vacuum into two pieces to expose the battery mounting area.
      Ask FixBot
      • Pull the air filter out of the front opening.
      • If you wash the filter, let it dry completely before reinstalling it.
      • Use a Phillips screwdriver to remove the front battery screw.
      • Use a Phillips screwdriver to remove the rear battery screw.
      • Keep track of the rear screw, because the longer screw goes in the back during reassembly.
      Ask FixBot
      • Slide the battery out through the bottom of the handle.
      • Inspect the top of the old battery before ordering a replacement.
      • Choose a Type B battery if the old battery has a tab on top.
      • Choose an Type A battery if the old battery has no tab on top.
      Ask FixBot
      • Buy a replacement battery that matches the A style or Type B battery removed from the vacuum.
      • Compare the new battery with the old battery before installation, especially the top tab shape.
      • Do not rely only on the vacuum model name when ordering, because compatible models can use different battery styles.
      • This battery style check also applies to similar Dyson cordless models such as the DC34, DC44, and DC45.
      Ask FixBot
      • Insert the replacement battery up through the bottom of the handle.
      • Align the battery so the screw holes line up with the handle.
      • Use a Phillips screwdriver to install the longer screw in the rear battery hole and tighten it.
      • Use needle nose pliers to position the front screw in the front hole if it is hard to start.
      • Use a Phillips screwdriver to seat and tighten the front screw.
      Ask FixBot
      • Insert the air filter into the front opening with its small tab facing up.
      • Join the two vacuum sections by placing the lower side first.
      • Press the top of the sections together until they click into place.
      • Press the trigger to confirm the vacuum runs again.
      Ask FixBot
      • Recycle the old battery pack through an approved battery recycling program.
      • Do not cut the wires or disassemble the old battery pack.
      • The internal cells and circuit board are soldered together and aren't part of this replacement procedure.
      Ask FixBot
After installing a new battery, charge it to 100%, and keep charging it for at least two more hours. Use the vacuum until it shuts off because of a low battery, then charge it uninterrupted to 100%.
Charge the new battery before normal use if it isn't already charged. Take your e-waste to an R2 or e-Stewards certified recycler. Repair didn't go as planned? Ask our Answers community for help.
eCuration
478,744 Reputation
396 Guides authored
0 Guide Comments
Past 24 Hours: 7
Past 7 Days: 49
Past 30 Days: 134
All Time: 213
