Introduction
Step-by-step on how to either replace or readjust the L2/R2's rubber components on a dualshock PS4 controller (Model CUH-ZCT1).
Use a Phillips screwdriver to remove the four 6.4Â mm-long screws from the rear panel.
Insert an opening tool into the crease where the front and rear panel meet, starting from the outside edge of either handle.
Gently pry the rear panel off of the front panel until they become partially separated.
Use the opening tool to separate the panels by releasing the plastic clips around the perimeter of the controller.
Proceed to pry open the shell by squeezing the top end of the shell's handles then pull towards the back buttons.
Detach strip on bottom shell from the upper shell. There should be a blue-tab attachment where you are able to pry the strip from its connector for an easy disassemble.
Disconnect the connector that is connecting the battery to the motherboard. Remove the battery.
Next pull away the L2/R2 buttons from their positions. L2/R2 should be removed by carefully pulling vertically. Note There are two stubs on the side of it use a prying tool and gently pop them out.
Examine the controllers rubber guards to see if it needs to be replaced or simply needs to be readjusted. If it is damaged, replace the rubber guard with a new one for the correct model, then, proceed to the next step. If not, proceed to the next step.
Carefully slide the rubber guard with the area that sticks out more going down into the slot (The crater part of the rubber guard should be in place for the R2/L2 slots; see picture for directions). Once in place, ensure it is snugged and secure.
The buttons should reset to normal position as it is being depressed.
Reconnect the battery.
Connect the strip back into the connector then close the shell starting from the triggers to the handles.
Screw all screws back into place.
