DualSense Edge Joysticks Replacement
  1. DualSense Edge Joysticks Replacement, Remove the front trim: step 1, image 1 of 3 DualSense Edge Joysticks Replacement, Remove the front trim: step 1, image 2 of 3 DualSense Edge Joysticks Replacement, Remove the front trim: step 1, image 3 of 3
    • Place the controller on a work surface with the joysticks facing down.
    • Use a spudger or your finger to slide the Release tab to the left. The front trim should fall to the table.
    • If the front trim doesn't fall open, make sure the front trim has room to fall down and the Release tab is pushed all the way to the left.
    • Lift the controller up, leaving the front trim on the table.
    • During reassembly, insert the front trim at an angle so the top slots in first, then lower the trim into place and snap it onto the controller.
  2. DualSense Edge Joysticks Replacement, Remove the joysticks: step 2, image 1 of 3 DualSense Edge Joysticks Replacement, Remove the joysticks: step 2, image 2 of 3 DualSense Edge Joysticks Replacement, Remove the joysticks: step 2, image 3 of 3
    • Flip the controller over so the joysticks are facing up.
    • Lift the metal lever that holds the joystick in place until the joystick slides out slightly.
    • Slide the joystick out from its slot.
  3. DualSense Edge Joysticks Replacement: step 3, image 1 of 1
    • Repeat this process to remove the other joystick.
4 other people completed this guide.
Spencer Pennington
23,410 Reputation
125 Guides authored
Guide Team Member of Guide Team
Staff
10 Members
15,914 Guides authored
0 Guide Comments
Past 24 Hours: 30
Past 7 Days: 166
Past 30 Days: 700
All Time: 8,863
