Droid Ultra XT1080 Power Button Replacement
  1. Droid Ultra XT1080 Power Button Replacement, Power Button: step 1, image 1 of 3 Droid Ultra XT1080 Power Button Replacement, Power Button: step 1, image 2 of 3 Droid Ultra XT1080 Power Button Replacement, Power Button: step 1, image 3 of 3
    • Gently remove the SIM card tray from the device using a spudger.
  2. Droid Ultra XT1080 Power Button Replacement: step 2, image 1 of 1
    • After SIM card removal press the spudger between the plastic case and the frame until you hear a snap.
    • Work your way around the device until all the clips are released.
    • Be gentle while doing this so you don't crack or break the plastic.
  3. Droid Ultra XT1080 Power Button Replacement: step 3, image 1 of 1
    • Remove the five screws on top of the device with a T5 Torx.
    • Remove the single screw holding the camera with a T4 Torx.
    • Remove the two screws on the bottom of the device with a T5 Torx.
  4. Droid Ultra XT1080 Power Button Replacement: step 4, image 1 of 2 Droid Ultra XT1080 Power Button Replacement: step 4, image 2 of 2
    • Once the screws are removed, use a nylon spudger and lift up on the two plastic pieces that were secured by the screws.
  5. Droid Ultra XT1080 Power Button Replacement: step 5, image 1 of 1
    • Remove the four T5 Torx screws securing the motherboard.
  6. Droid Ultra XT1080 Power Button Replacement: step 6, image 1 of 1
    • Gently pry the motherboard out of the frame using the plastic opening tool.
  7. Droid Ultra XT1080 Power Button Replacement: step 7, image 1 of 2 Droid Ultra XT1080 Power Button Replacement: step 7, image 2 of 2
    • Once motherboard is removed you have gained access to the power button.
    • Gently, using a pair of angled tweezers pull on the power button to remove it.
knoyes
785 Reputation
5 Guides authored
Past 24 Hours: 0
Past 7 Days: 5
Past 30 Days: 12
All Time: 301
