Introduction
This guide will show how to replace damaged casing on the Dremel MultiPro 395.
Remove the blue caps located on either side of the MultiPro, using a 3 mm flathead screwdriver.
Carefully remove the carbon brushes attached at the end of the springs by gently pulling on the springs using your hands.
Pull one side of the hanger up and then pull away from the Multipro until the other side can be pulled out.
Hold down the collet lock, remove the chuck cap from the top of the Multipro by screwing counterclockwise.
