Dremel MultiPro 395 Casing Replacement
  1. Dremel MultiPro 395 Casing Replacement, Casing: step 1, image 1 of 2 Dremel MultiPro 395 Casing Replacement, Casing: step 1, image 2 of 2
    • Remove the blue caps located on either side of the MultiPro, using a 3 mm flathead screwdriver.
  2. Dremel MultiPro 395 Casing Replacement: step 2, image 1 of 2 Dremel MultiPro 395 Casing Replacement: step 2, image 2 of 2
    • Carefully remove the carbon brushes attached at the end of the springs by gently pulling on the springs using your hands.
  3. Dremel MultiPro 395 Casing Replacement: step 3, image 1 of 2 Dremel MultiPro 395 Casing Replacement: step 3, image 2 of 2
    • Pull one side of the hanger up and then pull away from the Multipro until the other side can be pulled out.
  4. Dremel MultiPro 395 Casing Replacement: step 4, image 1 of 3 Dremel MultiPro 395 Casing Replacement: step 4, image 2 of 3 Dremel MultiPro 395 Casing Replacement: step 4, image 3 of 3
    • Remove the 4 screws located on the bottom of the Multipro with a T15 screwdriver.
  5. Dremel MultiPro 395 Casing Replacement: step 5, image 1 of 3 Dremel MultiPro 395 Casing Replacement: step 5, image 2 of 3 Dremel MultiPro 395 Casing Replacement: step 5, image 3 of 3
    • Hold down the collet lock, remove the chuck cap from the top of the Multipro by screwing counterclockwise.
  6. Dremel MultiPro 395 Casing Replacement: step 6, image 1 of 3 Dremel MultiPro 395 Casing Replacement: step 6, image 2 of 3 Dremel MultiPro 395 Casing Replacement: step 6, image 3 of 3
    • Remove the black housing cap from the Multipro located directly below the chuck cap.
  7. Dremel MultiPro 395 Casing Replacement: step 7, image 1 of 3 Dremel MultiPro 395 Casing Replacement: step 7, image 2 of 3 Dremel MultiPro 395 Casing Replacement: step 7, image 3 of 3
    • Pull the bottom side of the casing up to remove it.
  8. Dremel MultiPro 395 Casing Replacement: step 8, image 1 of 3 Dremel MultiPro 395 Casing Replacement: step 8, image 2 of 3 Dremel MultiPro 395 Casing Replacement: step 8, image 3 of 3
    • Gently lift the motor shaft out of the Multipro.
  9. Dremel MultiPro 395 Casing Replacement: step 9, image 1 of 3 Dremel MultiPro 395 Casing Replacement: step 9, image 2 of 3 Dremel MultiPro 395 Casing Replacement: step 9, image 3 of 3
    • Pull the lock pin and its casing out of the other side of the Multipro case.
Past 24 Hours: 2
Past 7 Days: 3
Past 30 Days: 12
All Time: 2,151
