Dremel 4000 Back Case Replacement
Prerequisite Only
This guide is only intended to be used as a prerequisite for other guides. It's incomplete by itself.
  1. Dremel 4000 Back Case Replacement, Dremel 4000 Back Case Replacement: step 1, image 1 of 2 Dremel 4000 Back Case Replacement, Dremel 4000 Back Case Replacement: step 1, image 2 of 2
    • Start by removing the housing cap by unscrewing it.
    • Next, unscrew the now exposed collet nut while holding down the shaft lock button.
    • To remove the collet nut, you may need to use the small open-end wrench provided with the Dremel.
  2. Dremel 4000 Back Case Replacement: step 2, image 1 of 1
    • Using your hands, carefully remove hanger from casing.
  3. Dremel 4000 Back Case Replacement: step 3, image 1 of 2 Dremel 4000 Back Case Replacement: step 3, image 2 of 2
    • Remove the brush caps (one on each side) by using a flathead screwdriver bit.
    • The brush caps are spring loaded.
  4. Dremel 4000 Back Case Replacement: step 4, image 1 of 1
    • Using the Torx 15 screwdriver tip, remove the 5 screws (12.5 mm) that hold the casing together.
  5. Dremel 4000 Back Case Replacement: step 5, image 1 of 1
    • Use a plastic opening tool to gently wedge apart the hard plastic threads.
  6. Dremel 4000 Back Case Replacement: step 6, image 1 of 1
    • Use your hands to carefully remove the back casing so that none of the components fall out.
John Cobb
1,689 Reputation
4 Guides authored
USF Tampa, Team 15-4, Remmell Spring 2016 Member of USF Tampa, Team 15-4, Remmell Spring 2016
USFT-REMMELL-S16S15G4
4 Members
13 Guides authored
Past 24 Hours: 1
Past 7 Days: 10
Past 30 Days: 15
All Time: 1,670
