Up to 20% off select tools
Display Cable Disconnection
View statistics:
Past 24 Hours:
0
Past 7 Days:
5
Past 30 Days:
16
All Time:
294
Comments: 3
3 comments on steps.
Completed: 0
Favorites: 0
Time Required: No estimate
Difficulty: Moderate
Prerequisite Only
This is a prerequisite-only guide! This guide is part of another procedure and isn’t meant to be used alone.
Tools
Introduction
Go to step 1 ↓
This is a prerequisite-only guide! This guide is part of another procedure and is not meant to be used alone.
How to disconnect the display cable on a Samsung Galaxy Note20 Ultra.
    1. Display Cable Disconnection, Heat the rear cover: step 1, image 1 of 1
      • Completely power off your phone before you begin disassembly.
      • Heat an iOpener and apply it to the left side of the rear cover for one minute.
      • A hair dryer, heat gun, or hot plate may also be used, but be careful not to overheat the phone—the screen and internal battery are susceptible to heat damage.
      Ask FixBot
    2. Display Cable Disconnection, Insert an opening pick: step 2, image 1 of 3 Display Cable Disconnection, Insert an opening pick: step 2, image 2 of 3 Display Cable Disconnection, Insert an opening pick: step 2, image 3 of 3
      • Apply a suction cup to the heated edge of the rear cover, as close to the edge as possible.
      • If your back glass is badly cracked, covering it with a layer of clear packing tape may allow the suction cup to adhere. Alternatively, very strong tape may be used instead of the suction cup. If all else fails, you can superglue the suction cup to the broken panel.
      • Pull up on the suction cup with strong, steady force to create a gap between the rear cover and the frame.
      • Depending on the age of your phone, this may be difficult. If you are having trouble, apply more heat to the edge and try again.
      • Insert an opening pick into the gap.
      • Don't insert the opening pick more than 5 mm into the phone or you risk damaging the internal components.
      Ask FixBot
    3. Display Cable Disconnection, Begin to cut the adhesive: step 3, image 1 of 3 Display Cable Disconnection, Begin to cut the adhesive: step 3, image 2 of 3 Display Cable Disconnection, Begin to cut the adhesive: step 3, image 3 of 3
      • Slide the opening pick along the left edge towards the bottom left corner to cut through the adhesive.
      • Leave the pick inserted in the bottom left corner to prevent the adhesive from re-sealing.
      Ask FixBot
    4. Display Cable Disconnection, Cut along the perimeter of the rear cover: step 4, image 1 of 3 Display Cable Disconnection, Cut along the perimeter of the rear cover: step 4, image 2 of 3 Display Cable Disconnection, Cut along the perimeter of the rear cover: step 4, image 3 of 3
      • While cutting through the adhesive, don't insert the opening pick more than 5 mm into the phone or you risk damaging the internal components.
      • Repeat the process of heating and cutting the adhesive along the three remaining sides of the rear cover.
      • You can insert each new opening pick in the gaps created by the opening picks left in each corner.
      • As you proceed, leave an opening pick in each corner to prevent the adhesive from re-sealing.
      • Slide an opening pick back and forth around the entire perimeter of the phone to release any missed adhesive. Reheat any stubborn adhesive.
      Ask FixBot
    5. Display Cable Disconnection, Remove the rear cover: step 5, image 1 of 2 Display Cable Disconnection, Remove the rear cover: step 5, image 2 of 2
      • Lift the rear cover straight up to remove it.
      Ask FixBot
    1. Display Cable Disconnection, Disconnect the wireless charging coil: step 6, image 1 of 2 Display Cable Disconnection, Disconnect the wireless charging coil: step 6, image 2 of 2
      • Use the pointed end of a spudger to pry up and disconnect the wireless charging coil press connector.
      • Take care to pry only under the edge of the connector to prevent damaging the socket itself and surrounding components.
      • To re-attach press connectors like this one, carefully align and press down on one side until it clicks into place, then repeat on the other side. Do not press down on the middle. If the connector is misaligned, the pins can bend, causing permanent damage.
      Ask FixBot
    2. Display Cable Disconnection, Disconnect the white press connector: step 7, image 1 of 2 Display Cable Disconnection, Disconnect the white press connector: step 7, image 2 of 2
      • Use the pointed end of a spudger to pry up and disconnect the white press connector located in the bottom right of the motherboard shield.
      Ask FixBot
    3. Display Cable Disconnection, Remove the motherboard shield screws: step 8, image 1 of 1
      Tool used on this step:
      Magnetic Project Mat
      $16.96
      Buy
      • Use a Phillips screwdriver to remove the six 4.0 mm screws securing the motherboard shield.
      • If these screws have not been removed before, they may be difficult to remove as they have threadlocker on their threads.
      Ask FixBot
    4. Display Cable Disconnection, Remove the wireless charging coil: step 9, image 1 of 3 Display Cable Disconnection, Remove the wireless charging coil: step 9, image 2 of 3 Display Cable Disconnection, Remove the wireless charging coil: step 9, image 3 of 3
      Buy
      • Use a pair of tweezers to lift up the motherboard shield.
      • Be careful when handling the motherboard shield because its edges are thin and sharp.
      • Use your fingers to grip the motherboard shield.
      Ask FixBot
    5. Display Cable Disconnection: step 10, image 1 of 3 Display Cable Disconnection: step 10, image 2 of 3 Display Cable Disconnection: step 10, image 3 of 3
      • Peel the wireless charging coil up and away from the device to remove it.
      • The wireless charging coil is secured to the device with light adhesive.
      Ask FixBot
    1. Display Cable Disconnection, Disconnect the battery: step 11, image 1 of 2 Display Cable Disconnection, Disconnect the battery: step 11, image 2 of 2
      • Use the pointed end of a spudger to pry up the battery press connector to safely disconnect the battery before continuing repairs.
      Ask FixBot
    1. Display Cable Disconnection, Disconnect the display cable: step 12, image 1 of 2 Display Cable Disconnection, Disconnect the display cable: step 12, image 2 of 2
      • Use the pointed end of a spudger to disconnect the display cable from the motherboard.
      Ask FixBot
Kyle Smith
53,775 Reputation
124 Guides authored
0 Guide Comments
Past 24 Hours: 0
Past 7 Days: 5
Past 30 Days: 16
All Time: 294
