Google Pixel 9 Pro Fold Outer Screen Removal
Prerequisite Only
This is a prerequisite-only guide! This guide is part of another procedure and isn’t meant to be used alone.
  1. Google Pixel 9 Pro Fold Outer Screen Removal, Prepare your phone for disassembly: step 1, image 1 of 1
    • Let your phone's battery drain below 25% before starting this repair. A charged lithium‑ion battery may catch fire if damaged.
    • Unplug all cables from your phone and completely power it down.
  2. Google Pixel 9 Pro Fold Outer Screen Removal, Insert an opening pick: step 2, image 1 of 3 Google Pixel 9 Pro Fold Outer Screen Removal, Insert an opening pick: step 2, image 2 of 3 Google Pixel 9 Pro Fold Outer Screen Removal, Insert an opening pick: step 2, image 3 of 3
    • Apply a suction cup to the screen, as close to the center of the bottom edge as possible.
    • Pull up on the suction cup with strong, steady force to create a gap between the screen and the frame.
    • Insert an opening pick into the gap.
    • If your screen is badly cracked, covering it with a layer of clear packing tape may allow the suction cup to adhere. Alternatively, very strong tape may be used instead of the suction cup. If all else fails, you can superglue the suction cup to the screen.
  3. Google Pixel 9 Pro Fold Outer Screen Removal, Separate the adhesive: step 3, image 1 of 3 Google Pixel 9 Pro Fold Outer Screen Removal, Separate the adhesive: step 3, image 2 of 3 Google Pixel 9 Pro Fold Outer Screen Removal, Separate the adhesive: step 3, image 3 of 3
    • During the next four steps, don't insert your opening pick deeper than 3 mm to prevent damaging internal components.
    • Optionally, you can measure and mark your opening pick 3 mm from the tip to help you visualize the length.
    • Slide the opening pick around the bottom right corner and up the right edge of the screen to separate the adhesive.
  4. Google Pixel 9 Pro Fold Outer Screen Removal: step 4, image 1 of 3 Google Pixel 9 Pro Fold Outer Screen Removal: step 4, image 2 of 3 Google Pixel 9 Pro Fold Outer Screen Removal: step 4, image 3 of 3
    • Slide the pick around the top right corner and stop before the front camera.
  5. Google Pixel 9 Pro Fold Outer Screen Removal: step 5, image 1 of 3 Google Pixel 9 Pro Fold Outer Screen Removal: step 5, image 2 of 3 Google Pixel 9 Pro Fold Outer Screen Removal: step 5, image 3 of 3
    • Pull the opening pick out so only the tip is under the screen.
    • Slide the opening pick across the top edge of the screen until you're past the front camera.
    • Push your pick to its original depth before continuing.
  6. Google Pixel 9 Pro Fold Outer Screen Removal: step 6, image 1 of 3 Google Pixel 9 Pro Fold Outer Screen Removal: step 6, image 2 of 3 Google Pixel 9 Pro Fold Outer Screen Removal: step 6, image 3 of 3
    • Slide the opening pick around the top left corner and stop about two‑thirds down the left edge of the screen.
    • Don't slide the pick any farther, or you risk damaging the display cable.
  7. Google Pixel 9 Pro Fold Outer Screen Removal: step 7, image 1 of 3 Google Pixel 9 Pro Fold Outer Screen Removal: step 7, image 2 of 3 Google Pixel 9 Pro Fold Outer Screen Removal: step 7, image 3 of 3
    • Pull the opening pick out to a 2 mm depth and rotate the pick around the bottom left corner to separate the remaining adhesive.
  8. Google Pixel 9 Pro Fold Outer Screen Removal: step 8, image 1 of 3 Google Pixel 9 Pro Fold Outer Screen Removal: step 8, image 2 of 3 Google Pixel 9 Pro Fold Outer Screen Removal: step 8, image 3 of 3
    • Don't fully remove the screen yet, as it's still connected to the phone by a cable.
    • At this point, the screen should be free from the frame. If there's still resistance around the edges, use an opening pick to separate any remaining adhesive.
    • Lift the right edge of the screen and swing it over the left edge of the phone, like opening a book.
    • Prop up the screen with your suction handle or a clean, sturdy object.
  9. Google Pixel 9 Pro Fold Outer Screen Removal, Remove the display cable bracket screw: step 9, image 1 of 2 Google Pixel 9 Pro Fold Outer Screen Removal, Remove the display cable bracket screw: step 9, image 2 of 2
    Tool used on this step:
    FixMat
    $36.95
    Buy
    • While the Pixel 9 Pro Fold uses Torx Plus screws, standard Torx bits also work. Use the same size or one size larger (T3 or T4 Torx bits with 3IP Torx Plus screws) and apply constant, downward force to prevent stripping.
    • Use a Torx Plus 3IP driver to remove the 2.2 mm‑long screw securing the display cable bracket.
  10. Google Pixel 9 Pro Fold Outer Screen Removal: step 10, image 1 of 2 Google Pixel 9 Pro Fold Outer Screen Removal: step 10, image 2 of 2
    • Conductive tape secures the display cable bracket to the frame.
    • Use a spudger, or your fingers, to lift the display cable bracket enough to access the press connector underneath.
  11. Google Pixel 9 Pro Fold Outer Screen Removal, Disconnect the display cable: step 11, image 1 of 2 Google Pixel 9 Pro Fold Outer Screen Removal, Disconnect the display cable: step 11, image 2 of 2
    • Use the point of a spudger to pry up and disconnect the display cable press connector.
  12. Google Pixel 9 Pro Fold Outer Screen Removal, Remove the screen: step 12, image 1 of 1
    • Lift the screen off the frame and remove it.
Compare your new replacement part to the original part—you may need to transfer remaining components or remove adhesive backings from the new part before you install it.
Repair didn’t go as planned? Try some basic troubleshooting, or ask our Google Pixel 9 Pro Fold Answers Community for help.
Alex Diaz-Kokaisl
216,864 Reputation
1,047 Guides authored
iFixit Member of iFixit
Staff
123 Members
23,922 Guides authored
0 Guide Comments
Past 24 Hours: 0
Past 7 Days: 3
Past 30 Days: 13
All Time: 109
