Google Pixel 9 Pro Fold Lower Board Disconnection Removal
Prerequisite Only
This is a prerequisite-only guide! This guide is part of another procedure and isn’t meant to be used alone.
  1. Google Pixel 9 Pro Fold Lower Board Disconnection Removal, Prepare your phone for disassembly: step 1, image 1 of 1
    • Let your phone's battery drain below 25% before starting this repair. A charged lithium‑ion battery may catch fire if damaged.
    • Unplug all cables from your phone and completely power it down.
  2. Google Pixel 9 Pro Fold Lower Board Disconnection Removal, Insert an opening pick: step 2, image 1 of 3 Google Pixel 9 Pro Fold Lower Board Disconnection Removal, Insert an opening pick: step 2, image 2 of 3 Google Pixel 9 Pro Fold Lower Board Disconnection Removal, Insert an opening pick: step 2, image 3 of 3
    • Apply a suction cup to the screen, as close to the center of the bottom edge as possible.
    • Pull up on the suction cup with strong, steady force to create a gap between the screen and the frame.
    • Insert an opening pick into the gap.
    • If your screen is badly cracked, covering it with a layer of clear packing tape may allow the suction cup to adhere. Alternatively, very strong tape may be used instead of the suction cup. If all else fails, you can superglue the suction cup to the screen.
  3. Google Pixel 9 Pro Fold Lower Board Disconnection Removal, Separate the adhesive: step 3, image 1 of 3 Google Pixel 9 Pro Fold Lower Board Disconnection Removal, Separate the adhesive: step 3, image 2 of 3 Google Pixel 9 Pro Fold Lower Board Disconnection Removal, Separate the adhesive: step 3, image 3 of 3
    • During the next four steps, don't insert your opening pick deeper than 3 mm to prevent damaging internal components.
    • Optionally, you can measure and mark your opening pick 3 mm from the tip to help you visualize the length.
    • Slide the opening pick around the bottom right corner and up the right edge of the screen to separate the adhesive.
  4. Google Pixel 9 Pro Fold Lower Board Disconnection Removal: step 4, image 1 of 3 Google Pixel 9 Pro Fold Lower Board Disconnection Removal: step 4, image 2 of 3 Google Pixel 9 Pro Fold Lower Board Disconnection Removal: step 4, image 3 of 3
    • Slide the pick around the top right corner and stop before the front camera.
  5. Google Pixel 9 Pro Fold Lower Board Disconnection Removal: step 5, image 1 of 3 Google Pixel 9 Pro Fold Lower Board Disconnection Removal: step 5, image 2 of 3 Google Pixel 9 Pro Fold Lower Board Disconnection Removal: step 5, image 3 of 3
    • Pull the opening pick out so only the tip is under the screen.
    • Slide the opening pick across the top edge of the screen until you're past the front camera.
    • Push your pick to its original depth before continuing.
  6. Google Pixel 9 Pro Fold Lower Board Disconnection Removal: step 6, image 1 of 3 Google Pixel 9 Pro Fold Lower Board Disconnection Removal: step 6, image 2 of 3 Google Pixel 9 Pro Fold Lower Board Disconnection Removal: step 6, image 3 of 3
    • Slide the opening pick around the top left corner and stop about two‑thirds down the left edge of the screen.
    • Don't slide the pick any farther, or you risk damaging the display cable.
  7. Google Pixel 9 Pro Fold Lower Board Disconnection Removal: step 7, image 1 of 3 Google Pixel 9 Pro Fold Lower Board Disconnection Removal: step 7, image 2 of 3 Google Pixel 9 Pro Fold Lower Board Disconnection Removal: step 7, image 3 of 3
    • Pull the opening pick out to a 2 mm depth and rotate the pick around the bottom left corner to separate the remaining adhesive.
  8. Google Pixel 9 Pro Fold Lower Board Disconnection Removal: step 8, image 1 of 3 Google Pixel 9 Pro Fold Lower Board Disconnection Removal: step 8, image 2 of 3 Google Pixel 9 Pro Fold Lower Board Disconnection Removal: step 8, image 3 of 3
    • Don't fully remove the screen yet, as it's still connected to the phone by a cable.
    • At this point, the screen should be free from the frame. If there's still resistance around the edges, use an opening pick to separate any remaining adhesive.
    • Lift the right edge of the screen and swing it over the left edge of the phone, like opening a book.
    • Prop up the screen with your suction handle or a clean, sturdy object.
  9. Google Pixel 9 Pro Fold Lower Board Disconnection Removal, Remove the display cable bracket screw: step 9, image 1 of 2 Google Pixel 9 Pro Fold Lower Board Disconnection Removal, Remove the display cable bracket screw: step 9, image 2 of 2
    Tool used on this step:
    FixMat
    $36.95
    Buy
    • While the Pixel 9 Pro Fold uses Torx Plus screws, standard Torx bits also work. Use the same size or one size larger (T3 or T4 Torx bits with 3IP Torx Plus screws) and apply constant, downward force to prevent stripping.
    • Use a Torx Plus 3IP driver to remove the 2.2 mm‑long screw securing the display cable bracket.
  10. Google Pixel 9 Pro Fold Lower Board Disconnection Removal: step 10, image 1 of 2 Google Pixel 9 Pro Fold Lower Board Disconnection Removal: step 10, image 2 of 2
    • Conductive tape secures the display cable bracket to the frame.
    • Use a spudger, or your fingers, to lift the display cable bracket enough to access the press connector underneath.
  11. Google Pixel 9 Pro Fold Lower Board Disconnection Removal, Disconnect the display cable: step 11, image 1 of 2 Google Pixel 9 Pro Fold Lower Board Disconnection Removal, Disconnect the display cable: step 11, image 2 of 2
    • Use the point of a spudger to pry up and disconnect the display cable press connector.
  12. Google Pixel 9 Pro Fold Lower Board Disconnection Removal, Remove the screen: step 12, image 1 of 1
    • Lift the screen off the frame and remove it.
  13. Google Pixel 9 Pro Fold Lower Board Disconnection Removal, Remove the battery bracket screw: step 13, image 1 of 2 Google Pixel 9 Pro Fold Lower Board Disconnection Removal, Remove the battery bracket screw: step 13, image 2 of 2
    • Use a Torx Plus 3IP driver to remove the 2.0 mm‑long screw securing the battery bracket.
  14. Google Pixel 9 Pro Fold Lower Board Disconnection Removal, Disconnect the battery: step 14, image 1 of 2 Google Pixel 9 Pro Fold Lower Board Disconnection Removal, Disconnect the battery: step 14, image 2 of 2
    • Conductive tape secures the battery connector bracket to the lower board.
    • Use tweezers, or your fingers, to move the battery bracket out of the way of the battery press connector.
  15. Google Pixel 9 Pro Fold Lower Board Disconnection Removal: step 15, image 1 of 2 Google Pixel 9 Pro Fold Lower Board Disconnection Removal: step 15, image 2 of 2
    • Use the point of a spudger to pry up and disconnect the battery press connector.
  16. Google Pixel 9 Pro Fold Lower Board Disconnection Removal, Remove the bottom interconnect cable bracket screws: step 16, image 1 of 2 Google Pixel 9 Pro Fold Lower Board Disconnection Removal, Remove the bottom interconnect cable bracket screws: step 16, image 2 of 2
    • Use a Torx Plus 3IP driver to remove the two 2.2 mm‑long screws securing the bottom interconnect cable bracket.
  17. Google Pixel 9 Pro Fold Lower Board Disconnection Removal, Remove the bottom interconnect cable bracket: step 17, image 1 of 3 Google Pixel 9 Pro Fold Lower Board Disconnection Removal, Remove the bottom interconnect cable bracket: step 17, image 2 of 3 Google Pixel 9 Pro Fold Lower Board Disconnection Removal, Remove the bottom interconnect cable bracket: step 17, image 3 of 3
    • Use tweezers, or your fingers, to remove the bottom interconnect cable bracket from the lower board.
  18. Google Pixel 9 Pro Fold Lower Board Disconnection Removal, Disconnect the bottom interconnect cable: step 18, image 1 of 2 Google Pixel 9 Pro Fold Lower Board Disconnection Removal, Disconnect the bottom interconnect cable: step 18, image 2 of 2
    • Insert a spudger under the right edge of the bottom interconnect cable press connector.
    • Don't insert your spudger anywhere else, as you risk dislodging surface‑mounted components.
    • Pry up and disconnect the bottom interconnect cable.
  19. Google Pixel 9 Pro Fold Lower Board Disconnection Removal, Remove the SIM card tray: step 19, image 1 of 3 Google Pixel 9 Pro Fold Lower Board Disconnection Removal, Remove the SIM card tray: step 19, image 2 of 3 Google Pixel 9 Pro Fold Lower Board Disconnection Removal, Remove the SIM card tray: step 19, image 3 of 3
    • Insert a SIM eject tool, bit, or straightened paper clip into the SIM card tray hole and press firmly to eject it.
    • Remove the SIM card tray.
Compare your new replacement part to the original part—you may need to transfer remaining components or remove adhesive backings from the new part before you install it.
Repair didn’t go as planned? Try some basic troubleshooting, or ask our Google Pixel Pro 9 Fold Answers Community for help.
Alex Diaz-Kokaisl
226,655 Reputation
1,106 Guides authored
iFixit Member of iFixit
Staff
124 Members
24,259 Guides authored
0 Guide Comments
Past 24 Hours: 0
Past 7 Days: 0
Past 30 Days: 2
All Time: 95
