Disassembling Samsung Laptop Ultrabook NP530U3B
  1. Disassembling Samsung Laptop Ultrabook NP530U3B: step 2, image 1 of 2 Disassembling Samsung Laptop Ultrabook NP530U3B: step 2, image 2 of 2
    • Remove the other 6 screws.
    • Remove the hard disk and the RAM slots.
  2. Disassembling Samsung Laptop Ultrabook NP530U3B: step 3, image 1 of 1
    • This is the hard disk - Hitachi 500 GB
  3. Disassembling Samsung Laptop Ultrabook NP530U3B: step 4, image 1 of 1
    • Ensure that the hard disk has been removed. Carefully detach the bottom cover.
  4. Disassembling Samsung Laptop Ultrabook NP530U3B: step 5, image 1 of 1
    • Once the bottom cover is removed, your device should look like this.
  5. Disassembling Samsung Laptop Ultrabook NP530U3B: step 6, image 1 of 1
    • Remove the 4 screws to detach the battery.
    • Remove all of the sticky tape.
    • Carefully disconnect the small power connector by using a tool to push the connector out through the small gap in the middle of the connector.
    • The connector won't come out all the way, because the battery pack is in its way.
  6. Disassembling Samsung Laptop Ultrabook NP530U3B: step 7, image 1 of 2 Disassembling Samsung Laptop Ultrabook NP530U3B: step 7, image 2 of 2
    • This is the Samsung 7.4V 45Wh battery.
    • Ensure that the battery is removed before continuing.
  7. Disassembling Samsung Laptop Ultrabook NP530U3B: step 8, image 1 of 1
    • When the battery is removed, this is how it will look.
  8. Disassembling Samsung Laptop Ultrabook NP530U3B: step 9, image 1 of 1
    • Remove the processor fan.
    • There are 2 screws holding it in place. Loosen and remove them.
  9. Disassembling Samsung Laptop Ultrabook NP530U3B: step 10, image 1 of 1
    • This is the processor fan.
  10. Disassembling Samsung Laptop Ultrabook NP530U3B: step 11, image 1 of 1
    • Remove the processor heat sink.
    • 3 screws hold this part in place. Loosen and remove them.
  11. Disassembling Samsung Laptop Ultrabook NP530U3B: step 12, image 1 of 1
    • Disconnect the antenna cables from the WiFi card.
    • Remove the screw.
    • Be sure to match the colors when reattaching the cables.
  12. Disassembling Samsung Laptop Ultrabook NP530U3B: step 13, image 1 of 1
    • Remove the screw.
    • Lift the latch upwards to loosen the cable.
  13. Disassembling Samsung Laptop Ultrabook NP530U3B: step 14, image 1 of 1
    • Remove the screw.
  14. Disassembling Samsung Laptop Ultrabook NP530U3B: step 15, image 1 of 1
    • Remove the screw.
  15. Disassembling Samsung Laptop Ultrabook NP530U3B: step 16, image 1 of 1
    • To remove the Motherboard, carefully disconnect the cables.
  16. Disassembling Samsung Laptop Ultrabook NP530U3B: step 17, image 1 of 2 Disassembling Samsung Laptop Ultrabook NP530U3B: step 17, image 2 of 2
    • This is the Motherboard - there is a front and rear view.
Jose Gustavo Abreu Murta
4,598 Reputation
9 Guides authored
Past 24 Hours: 3
Past 7 Days: 15
Past 30 Days: 61
All Time: 52,973
