Disassembling Samsung Laptop Ultrabook NP530U3B
  1. Disassembling Samsung Laptop Ultrabook NP530U3B, Ultrabook NP530U3B: step 1, image 1 of 1
    • Remove the 8 small screws.
  2. Disassembling Samsung Laptop Ultrabook NP530U3B: step 2, image 1 of 2 Disassembling Samsung Laptop Ultrabook NP530U3B: step 2, image 2 of 2
    • Remove the other 6 screws.
    • Hard disk.
    • RAM slots.
  3. Disassembling Samsung Laptop Ultrabook NP530U3B: step 3, image 1 of 1
    • Hard disk - Hitachi 500 GB
  4. Disassembling Samsung Laptop Ultrabook NP530U3B: step 4, image 1 of 1
    • The hard disk should have been taken out before this step.
    • Carefully detach the bottom cover.
  5. Disassembling Samsung Laptop Ultrabook NP530U3B: step 5, image 1 of 1
    • Bottom cover removed
  6. Disassembling Samsung Laptop Ultrabook NP530U3B: step 6, image 1 of 1
    • Remove the 4 screws to detach the battery.
    • Remove all the sticky tape.
    • Carefully disconnect the small power connector by using a tool to push the connector out through the small gap mid-connector. It won't come out all the way, because the battery pack is in its way.
  7. Disassembling Samsung Laptop Ultrabook NP530U3B: step 7, image 1 of 2 Disassembling Samsung Laptop Ultrabook NP530U3B: step 7, image 2 of 2
    • Samsung 7.4V 45Wh battery.
  8. Disassembling Samsung Laptop Ultrabook NP530U3B: step 8, image 1 of 1
    • Battery removed.
  9. Disassembling Samsung Laptop Ultrabook NP530U3B: step 9, image 1 of 1
    • Remove Fan with Processor heat sink.
    • ( 2 screws)
  10. Disassembling Samsung Laptop Ultrabook NP530U3B: step 10, image 1 of 1
    • (3 screws)
  11. Disassembling Samsung Laptop Ultrabook NP530U3B: step 11, image 1 of 1
    • Disconnect antenna cables from WiFi card.
    • Remove the screw.
    • Be sure to match the colors when reattaching the cables.
  12. Disassembling Samsung Laptop Ultrabook NP530U3B: step 12, image 1 of 1
    • Remove this screw.
    • Uplift the latch to loose the cable.
  13. Disassembling Samsung Laptop Ultrabook NP530U3B: step 13, image 1 of 1
  14. Disassembling Samsung Laptop Ultrabook NP530U3B: step 14, image 1 of 1
  15. Disassembling Samsung Laptop Ultrabook NP530U3B: step 15, image 1 of 1
    • To remove Motherboard, carefully disconnect the cables.
  16. Disassembling Samsung Laptop Ultrabook NP530U3B: step 16, image 1 of 2 Disassembling Samsung Laptop Ultrabook NP530U3B: step 16, image 2 of 2
    • Motherboard - front and rear
  17. Disassembling Samsung Laptop Ultrabook NP530U3B: step 17, image 1 of 1
    • Processor fan.
Jose Gustavo Abreu Murta
4,598 Reputation
9 Guides authored
Past 24 Hours: 1
Past 7 Days: 9
Past 30 Days: 66
All Time: 52,942
