Disassembling Vaio FS series VGRFS640 BackPlate
  1. Disassembling Vaio FS series VGRFS640 BackPlate, Disassembling Vaio FS series VGRFS640 BackPlate: step 1, image 1 of 1
    • Turn off the laptop and disconnect any charging cables.
    • Flip the laptop over so that the Service Tag is shown at the top left corner.
  2. Disassembling Vaio FS series VGRFS640 BackPlate: step 2, image 1 of 1
    • Remove the highlighted screws from the back of the laptop with a Phillips #0 Screwdriver.
  3. Disassembling Vaio FS series VGRFS640 BackPlate: step 3, image 1 of 1
    • Remove the highlighted screws from the panels in the bottom right-hand corner of the laptop using the Phillips #0 Screwdriver.
  4. Disassembling Vaio FS series VGRFS640 BackPlate: step 4, image 1 of 1
    • Remove the two panels in the bottom right-hand corner by sliding in the direction of the arrows imprinted on the panels.
  5. Disassembling Vaio FS series VGRFS640 BackPlate: step 5, image 1 of 1
    • Remove the highlighted screws underneath the removed panels using the Phillips #0 Screwdriver.
  6. Disassembling Vaio FS series VGRFS640 BackPlate: step 6, image 1 of 1
    • Carefully remove the hard drive from the panel in the bottom right-hand corner of the laptop.
  7. Disassembling Vaio FS series VGRFS640 BackPlate: step 7, image 1 of 1
    • Locate the battery, located on the top side of the laptop to the right of the Service Tag .
    • Remove the battery by pressing inwards on the tabs on either side of the battery.
  8. Disassembling Vaio FS series VGRFS640 BackPlate: step 8, image 1 of 1
    • Remove cover in the top left side of the laptop next to the battery by pulling it outwards.
  9. Disassembling Vaio FS series VGRFS640 BackPlate: step 9, image 1 of 1
    • Remove the backplate of the laptop by pulling it away from the laptop.
shamaz
125 Reputation
1 Guide authored
Past 24 Hours: 0
Past 7 Days: 2
Past 30 Days: 12
All Time: 369
