Introduction
If you need to access the battery, volume and noise cancelling control buttons, or right speaker subassembly of your Sony WH-CH710N headphones, opening the right ear cup is an essential first step. This guide will walk you through the disassembly process, showing you how to safely remove the ear pad and access the internal components without causing damage. With careful handling and the right tools, you’ll be able to open the ear cup and prepare for further repairs or replacements.
Before you begin, power off the headphones and disconnect them from the charger and any connected audio cable.
Pinch the right ear pad cushion and gently pull it away from the ear cup to remove it.
To reassemble your device, follow these instructions in reverse order. Take your e-waste to an R2 or e-Stewards certified recycler.
