Disassembling Sony WH-CH710N Left Ear Cup
Prerequisite Only
This is a prerequisite-only guide! This guide is part of another procedure and isn’t meant to be used alone.
    1. Disassembling Sony WH-CH710N Left Ear Cup, Left Ear Cup: step 1, image 1 of 1
      • Pinch the left ear pad cushion and gently pull it away from the ear cup to remove it.
      Ask FixBot
    2. Disassembling Sony WH-CH710N Left Ear Cup: step 2, image 1 of 1
      • Use a Phillips #1 screwdriver to remove the four 4.0 mm screws from the outer ear plate.
      Ask FixBot
    3. Disassembling Sony WH-CH710N Left Ear Cup: step 3, image 1 of 2 Disassembling Sony WH-CH710N Left Ear Cup: step 3, image 2 of 2
      • Using even pressure around all edges, gently pull the black outer ear plate away from the cup of the headphone. It may be helpful to use the iFixit plastic opening tool to pry around the edge of the outer ear plate.
      • Do not yank the outer plate off, as it is still connected by delicate speaker wires. The plastic is fragile and may crack if excessive force is used.
      Ask FixBot
    4. Disassembling Sony WH-CH710N Left Ear Cup: step 4, image 1 of 1
      • Use a Phillips #1 screwdriver to remove the four 3.0 mm screws from the inner ear plate.
      Ask FixBot
    5. Disassembling Sony WH-CH710N Left Ear Cup: step 5, image 1 of 1
      • Gently grasp the black inner ear plate and pull it away from the ear cup, exposing the internal components.
      • The internal components are still attached to the wires, which are glued into the inner ear plate. Be extremely careful not to pull on the wires while performing this step.
      Ask FixBot
To reassemble your device, follow these instructions in reverse order. Take your e-waste to an R2 or e-Stewards certified recycler.
0 Guide Comments
Past 24 Hours: 1
Past 7 Days: 3
Past 30 Days: 19
All Time: 91
