Disassembling PlayStation 2 Slimline Outer Shell
  1. Disassembling PlayStation 2 Slimline Outer Shell, Outer Shell: step 1, image 1 of 1
    • Disconnect all cables from the console and flip the unit over to reveal its base.
  2. Disassembling PlayStation 2 Slimline Outer Shell: step 2, image 1 of 3 Disassembling PlayStation 2 Slimline Outer Shell: step 2, image 2 of 3 Disassembling PlayStation 2 Slimline Outer Shell: step 2, image 3 of 3
    • Locate the 6 feet on the base of the unit. Pry them off using a spudger to reveal the screws.
    • Note: One of the feet is located under the sticker shown in the photo. Removing this sticker will void any warranty with Sony.
  3. Disassembling PlayStation 2 Slimline Outer Shell: step 3, image 1 of 3 Disassembling PlayStation 2 Slimline Outer Shell: step 3, image 2 of 3 Disassembling PlayStation 2 Slimline Outer Shell: step 3, image 3 of 3
    • Remove all six 4.0 mm screws from the base of the unit using a #1 Phillips screwdriver.
  4. Disassembling PlayStation 2 Slimline Outer Shell: step 4, image 1 of 3 Disassembling PlayStation 2 Slimline Outer Shell: step 4, image 2 of 3 Disassembling PlayStation 2 Slimline Outer Shell: step 4, image 3 of 3
    • Starting at the corner at which the power and Ethernet ports are located, pry open the outer shell using a spudger and continue around the entire unit.
    • Note: You may use your hands for additional force to separate the two pieces of the outer shell.
Thomas Sullivan
4,005 Reputation
6 Guides authored
Past 24 Hours: 2
Past 7 Days: 20
Past 30 Days: 130
All Time: 11,123
