Philips Marathon Vacuum FC9202 disassembly
  1. Philips Marathon Vacuum FC9202 disassembly, Philips Marathon Vacuum FC9202 disassembly: step 1, image 1 of 3 Philips Marathon Vacuum FC9202 disassembly, Philips Marathon Vacuum FC9202 disassembly: step 1, image 2 of 3 Philips Marathon Vacuum FC9202 disassembly, Philips Marathon Vacuum FC9202 disassembly: step 1, image 3 of 3
    • To open the unit, first remove the filter cover, by removing the hinge after removing the end caps
  2. Philips Marathon Vacuum FC9202 disassembly: step 2, image 1 of 1
    • dismantle the handle of the filter cover, removing the Torx screws hidden under the handle
  3. Philips Marathon Vacuum FC9202 disassembly: step 3, image 1 of 3 Philips Marathon Vacuum FC9202 disassembly: step 3, image 2 of 3 Philips Marathon Vacuum FC9202 disassembly: step 3, image 3 of 3
    • the chrome plate can be removed with a screwdriver
    • remove the min/max button and the on/off button; removal of a torx screw
    • electronic card update
  4. Philips Marathon Vacuum FC9202 disassembly: step 4, image 1 of 1
    • To remove the housing, you must remove 7 additional Torx screws
  5. Philips Marathon Vacuum FC9202 disassembly: step 5, image 1 of 2 Philips Marathon Vacuum FC9202 disassembly: step 5, image 2 of 2
    • Rear filter removal
  6. Philips Marathon Vacuum FC9202 disassembly: step 6, image 1 of 1
    • Removal of 4 torx screws
  7. Philips Marathon Vacuum FC9202 disassembly: step 7, image 1 of 1
    • 2 Torx screws under the hinge
  8. Philips Marathon Vacuum FC9202 disassembly: step 8, image 1 of 1
    • 3 screws at the front of the housing
  9. Philips Marathon Vacuum FC9202 disassembly: step 9, image 1 of 1
    • housing removal
6 other people completed this guide.
Special thanks to these translators:
fr en
100%
These translators are helping us fix the world! Want to contribute?
Start translating ›
christophe
806 Reputation
2 Guides authored
7 Comments
Merci pour les infos.
Doc red and yellow - Reply
hallo
bei mir sind die raeder abgefallen,wissen sie wie man die wieder anbringt?
mfg
vural oral - Reply
Bis hierher super erklärt und bebildert. Aber, ich muss an den Motor. Sollte man aber auch schaffen. Wenn er soweit zerlegt ist dürfte das auch kein Problem sein. Gut gemacht
Peter Loehr - Reply
Hallo,
kann mir jemand die Bezeichnung von dem Triac nenne?
MfG
M.Classen
mat - Reply
Hello, Does anybody has the white main body that we can see on step 9 ?
Mickael Gouadec - Reply
ahhhhhhhhhhhh where is motherboard for ps4!!!!!!!!!!!
Kevin Jiang - Reply
Past 24 Hours: 6
Past 7 Days: 30
Past 30 Days: 151
All Time: 12,128
