Disassembling Olympus Stylus 725 SW Back Panel
  1. Disassembling Olympus Stylus 725 SW Back Panel, Disassembling Olympus Stylus 725 SW Battery: step 1, image 1 of 2 Disassembling Olympus Stylus 725 SW Back Panel, Disassembling Olympus Stylus 725 SW Battery: step 1, image 2 of 2
    • The battery is located on the bottom of the camera.
    • Remove the battery by placing your thumb on the bottom flap and sliding the release button away from the side the lens is on. (The screwdriver is simply used as a reference point, no screws need to be removed)
    • If the battery is dead, charge it for 60-90 minutes.
    • When installing a charged battery, align the battery appropriately. The positive signs and negative should line up.
  2. Disassembling Olympus Stylus 725 SW Back Panel, Back Panel: step 2, image 1 of 3 Disassembling Olympus Stylus 725 SW Back Panel, Back Panel: step 2, image 2 of 3 Disassembling Olympus Stylus 725 SW Back Panel, Back Panel: step 2, image 3 of 3
    • Unscrew the 3mm long cover screws at the corners of the camera using a #00 Philips Screwdriver.
    • Unscrew the 2mm long screws securing the sides of the camera which holds the back panel. Use the same screwdriver.
  3. Disassembling Olympus Stylus 725 SW Back Panel: step 3, image 1 of 2 Disassembling Olympus Stylus 725 SW Back Panel: step 3, image 2 of 2
    • Be careful when removing the back cover, you will need to detach the connecting ribbons
    • Detach the ribbons using your thumb, sliding them out of their slots.
Bobby Hodges
49 Reputation
6 Guides authored
Cal Poly, Team 33-71, Johann Spring 2010 Member of Cal Poly, Team 33-71, Johann Spring 2010
CPSU-JOHANN-S10S33G71
4 Members
6 Guides authored
Past 24 Hours: 0
Past 7 Days: 3
Past 30 Days: 21
All Time: 4,335
