Introduction
Use this guide to remove the back panel to access the components inside.
Remove the battery by placing your thumb on the bottom flap and sliding the release button away from the side the lens is on. (The screwdriver is simply used as a reference point, no screws need to be removed)
If the battery is dead, charge it for 60-90 minutes.
Unscrew the cover screw at the corners of the camera using a #00 Philips Screwdriver
Unscrew the secure tabs on the sides of the camera holding the back panel on using the same screw driver
